Old 11-28-2012, 12:10 PM   #766
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Odin544 View Post
I have an interesting issue and hope a few of you can give me a few ideas on what to check. I raced this last saturday and had two good (bad ) crashes. Both times I clipped the outside PVC pipe joint (where the PVC pipe slips together) and it ripped an arm off both times. First time it was the front arm. Second time it was the rear arm. I'm not surprised it broke an arm at all with how fast I was going when I clipped it. Thats not the issue. The issue is after fixing the second one (rear arm) I had it on the setup station and was checking everything. Decided to toss the toe gauge on the rear and noticed that the left was at 2 degrees in, and the right side was at 4 degrees in. I have the box toe blocks 3.0 in the rear and 0in the front. So I should have 3.0 in on both sides. I did loosen the screws holding the toe blocks and got it to 2.5L and 3.5R I haven't had time to mess with it since but will have time this coming weekend.
I did replace the hinge pin as it was slightly bent. It seemed to bind as I rotated it in the new arm at a certain spot. Could I have bent the toe blocks?
I will assume you checked toe after building the kit and it was correct?
One thing you should check is the wheel hex. Me for example, out the box i had the same issues as you. I tried new block holder and still had a big difference. I took hexes from another car and BAM, perfect!
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 11-28-2012, 02:47 PM   #767
nwv327's Avatar
i had kinda been hoping that they were going to stick with that acid green and black look but once again ive been disappointed =/ guess ill stick with my plan and go back to a tc6.1
xray t3/t4 viper vtx10r/vst, tc3 VTA novack edge/ballistic , rc18r reedy , losi muggy, axial exo MM2/castle 1415, losi 8ight T 2.0 /castle 1515/MM2 , proboat blackjack29 hobbywing 130 HV/turnigy super edf 6s =)
nwv327 is offline   Reply With Quote
Old 11-28-2012, 03:35 PM   #768
Odin544's Avatar
Trader Rating: 93 (100%+)
You pick a car based solely on color?
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 11-28-2012, 03:45 PM   #769
Odin544's Avatar
Originally Posted by Reese Bobby View Post
Hi Odin,
It seems like the front and rear blocks might not be aligned due to the left side being +1 degree and the right -1 (ie -2 and -4) degree relative to the expected -3 left and right. (Sounds like the LHS of the car was impacted). Failing that, I suppose its also worth checking that the hub and hub carrier are not also damaged. Not sure if you observed the toe while the wheel rotates? Curious to know what the answer is, please keep us posted.
Yes the left hand side was impacted. I did not check the outer hinge pin to see if it was bent though since it went in smooth. But with both sides being off slightly leads me to think its possibly in the rear toe block. Maybe I even tweaked one of the screws that holds it?
Originally Posted by stro3579 View Post
Odin, if all of your hubs are ok. Try and loosen the srews on your rear toe blocks and possibly the front center blocks. Then try and reseat everything. I had this issue with buliding a brand new car and this seem to help. Keep us posted on your findings.
I did loosen the rear toe blocks and it did seem to help some. I'll completely disassemble the rear this weekend and closely inspect each piece though.
I did check it when I first built it and everything was spot on. I'll check the wheel hex as well as the rear axles. I was at full speed towards the end of the straight when I clipped it. So it could have easily done quite a bit of damage that I just didn't notice.
All good suggestions guys. Thanks. I'll post up when I find the culprit.
TriCitiesRC.com
Old 11-28-2012, 03:47 PM   #770
Dave Johnson wins 17.5 TC at the US Indoor Champs in Cleveland.
Brian Wynn wins VTA.
Both using a VBC Wildfire.
ChuckNasty is offline   Reply With Quote
Old 11-28-2012, 04:08 PM   #771
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Congrats on the awesome performance Guys.....
And so the Campaign continues.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 11-30-2012, 09:53 AM   #772
nitrobeast's Avatar
Default New option parts
http://www.redrc.net/2012/11/vbc-rac...ts/#more-60270
Rui Goncalves
Old 12-12-2012, 08:21 PM   #773
3D-Seth's Avatar
Trader Rating: 21 (100%+)
Question for you guys...
Running my Wildfire on our small (70x30ft ish) carpet track. 17.5 Blinky. I'm having an issue that I can't seem to get resolved and not really certain what is causing it. We have a 180 sweeper off the straight, with about a 135 turn at the end of the sweeper. My car drives pretty well except that I feel like if I steer too hard, it will swap ends on me. I notice it most at the end of the sweeper above. On some of the other corners I feel like it is close to giving out the rear end, but never really does unless I screw up and give a little too much steering.
I wouldn't say it oversteers on power, mid corner or entry, but wouldn't say it pushes either. Just seems to happen when I get deep into steering.
I've tried softer rear springs, stiffer front springs. Tried all sway bars (front and rear), no sway bar (front and rear). Leaned the shocks all the way in on rear, all the way up in front, changed the wheel base to longer/shorter, changed the wheel base to move the chassis forward/backwards, swapped shocks left to right, rebuilt the shocks twice, rebuilt the diff and spool once (1000wt in diff), tried 3 sets of tires (2 sets of Sweep blues, 1 set of Jaco Blues, brand new, run-in, and old). I've tried no traction compound on front (pushes like crazy), none on rear or front, front only, half front etc etc.
The only thing I've changed recently was the front drive shafts (went to the double joints).
Any ideas?
Most everyone here is running 1000wt in the diff. Should I be running anything different? Medium grip carpet...
Thanks!
Seth
Track video, with current layout:
http://www.youtube.com/watch?v=NX2Higo51ig
3D-Seth is offline   Reply With Quote
Old 12-12-2012, 08:27 PM   #774
Odin544's Avatar
What is your setup?
TriCitiesRC.com
Old 12-12-2012, 08:33 PM   #775
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
Any ideas?
Thanks!
Seth
Have you tried adjusting your droop? Maybe you don't have enough rear droop and one wheel is coming off the carpet? You can also try lengthening the front camber link or shortening the rear camber link to adjust your camber gain. And you can start playing with your roll center.
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 12-12-2012, 08:40 PM   #776
3D-Seth's Avatar
Its been all over the board trying to get this issue fixed.
Generally speaking this is where I left off today:
Sweep Blues
Ride height - 5mm f/r
Front
0.5 toe out
1.5 camber
Arms in middle
Red Springs
Top, 2nd hole out
Bottom, outermost hole
Camber link
3rd hole out on camber block, 2mm spacer
Steering links - rear most hole
Droop is 3 on Dynamite droop gauge
Red swaybar
Belt, medium
Rear
Toe, stock, 3 deg I think?
1.5 camber
Arms forward (1 1mm spacer forward)
Orange rear springs
Top, 3rd hole out
Camber link
3rd hole out on camber block, 3mm spacer
outermost hole on hub
Droop is 3 on dynamite gauge
Red swaybar
Belt, loose
Orion 17.5
Tekin RS
JRS9100Z servo
49T pinion
96T Spur
1000wt diff oil
Protoform LTCR
At first I thought, maybe I've made the rear too soft and the rear of the chassis is hitting the ground as it rolls in the corners more causing it to lose a little rear grip, but I stiffened the rear quite a bit and didn't notice much difference (other than the rear getting really loose obviously)
Am I missing anything?
Old 12-12-2012, 08:48 PM   #777
3D-Seth's Avatar
Yup, tried the droop and camber links today. I started with 0 droop and backed the screws out 1 turn at a time for both front and rear individually. Tried every camber link position possible (besides raising/lowering ball studs, only had a couple hours).
Also, after running it last night, I brought the car home and checked all the hinge pins and shock shafts to make sure none were bent. Spent some time to free up the arms a little. Car seemed smoother today after freeing it up a bit more, but still had the same problem.
Seth
Old 12-12-2012, 09:56 PM   #778
What shock oil are you running front and rear? Also what shimming on your steering rack?
Sweep Blues
Front
0.5 toe out
1.5 camber
Arms in middle
Red Springs
Top, 2nd hole out
Camber link
Red swaybar
Belt, medium
Rear
1.5 camber
Orange rear springs
Top, 3rd hole out
Camber link
Red swaybar
Belt, loose
Orion 17.5
Tekin RS
JRS9100Z servo
49T pinion
96T Spur
1000wt diff oil
Protoform LTCR
Old 12-12-2012, 09:59 PM   #779
3D-Seth's Avatar
Originally Posted by Ron Goetter View Post
What shock oil are you running front and rear? Also what swimming on your steering rack?
Losi 35 in rear, 42.5 up front
Do you mean shimming? Steering rack is box stock.
Old 12-13-2012, 01:20 AM   #780
daleburr's Avatar
Sounds like a classic weight distribution issue to me. Try moving weight forwards any way possible. Or move both front and rear wishbones backwards which will also move the WD forwards, but well have side effects on drive shaft angle
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
