Old 11-12-2012, 12:59 AM   #751
Soupinmycoupe's Avatar
Trader Rating: 29 (100%+)
Thumbs up
Originally Posted by onearmbandit View Post
Thanks !
Problem solved
Greg; Im workin on getting a VBC, shhhhhh......
Soupinmycoupe is offline   Reply With Quote
Old 11-14-2012, 12:09 PM   #752
stro3579's Avatar
Trader Rating: 20 (100%+)
Originally Posted by locked View Post
Try around 6.5 FDR to start.
4.0 is a starting point for blinky. It's far too low for boosted.
Re: results from the Halloween Classic.
Nice job guys. Great driving Dave! I watched the races from Dirla's ustream. Sounded like everyone was having a good time.
Sorry, I over read the boosted part. Thought it was blinky.
stro3579 is offline   Reply With Quote
Old 11-14-2012, 11:38 PM   #753
onearmbandit's Avatar
HUH??
onearmbandit is offline   Reply With Quote
Old 11-15-2012, 04:25 AM   #754
Potoczak's Avatar
Trader Rating: 107 (100%+)
Any new info on the floating servo mounts? Eta on when they will be available??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 11-15-2012, 06:54 AM   #755
johnnywhopper's Avatar
in stock...
http://www.teamcrc.com/crc/modules.p...prodID=7719461
John
Team CRC, Spektrum, Hobbywing, JDJ Vinyl Graphics, Moby Graphix, Black Art, Power Push
johnnywhopper is offline   Reply With Quote
Old 11-16-2012, 09:16 AM   #756
Trader Rating: 23 (100%+)
If anyone is looking for a VBC wildfire with extras, please PM me.
Former RC fanatic just trying to keep up......
BSR Tires / Spektrum RC
Jamie Hanson is offline   Reply With Quote
Old 11-16-2012, 08:06 PM   #757
Default shock caps
I see some people are drilling holes in the shock caps. Is there a diagram on where to drill and the reason for it?
67fastbk is offline   Reply With Quote
Old 11-16-2012, 11:21 PM   #758
Odin544's Avatar
Trader Rating: 93 (100%+)
Just a 1mm hole to vent above the bladder so you can get zero rebound.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 11-23-2012, 04:01 PM   #759
Default BELT SIZES
Anyone have a replacement belt suggestion or know what the TOOTH count
is on the belts?
Or what belts are options on the VBC Wildfire
Old 11-23-2012, 06:34 PM   #760
Trader Rating: 19 (100%+)
is on the belts?
Here are the type R belts. They hold up much better then stock belts.
rear:
http://teamcrc.com/crc/modules.php?n...prodID=7719398
front:
http://teamcrc.com/crc/modules.php?n...prodID=7719397
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 11-23-2012, 06:56 PM   #761
Trader Rating: 39 (100%+)
Anyone got part numbers for the conversion of the front C-hubs and knuckles?
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 11-25-2012, 12:54 PM   #762
Reese Bobby's Avatar
Hi All,
I was wondering if anyone has given the Flex Chassis a try? Was there a noticeable difference?
Thanks in advance.
VBC Wildfires
Orca - Revolectrix - Sanwa - SMC
Reese Bobby is offline   Reply With Quote
Old 11-27-2012, 11:56 PM   #763
Odin544's Avatar
I have an interesting issue and hope a few of you can give me a few ideas on what to check. I raced this last saturday and had two good (bad ) crashes. Both times I clipped the outside PVC pipe joint (where the PVC pipe slips together) and it ripped an arm off both times. First time it was the front arm. Second time it was the rear arm. I'm not surprised it broke an arm at all with how fast I was going when I clipped it. Thats not the issue. The issue is after fixing the second one (rear arm) I had it on the setup station and was checking everything. Decided to toss the toe gauge on the rear and noticed that the left was at 2 degrees in, and the right side was at 4 degrees in. I have the box toe blocks 3.0 in the rear and 0 in the front. So I should have 3.0 in on both sides. I did loosen the screws holding the toe blocks and got it to 2.5L and 3.5R I haven't had time to mess with it since but will have time this coming weekend.
I did replace the hinge pin as it was slightly bent. It seemed to bind as I rotated it in the new arm at a certain spot. Could I have bent the toe blocks?
TriCitiesRC.com
Old 11-28-2012, 11:53 AM   #764
Hi Odin,
It seems like the front and rear blocks might not be aligned due to the left side being +1 degree and the right -1 (ie -2 and -4) degree relative to the expected -3 left and right. (Sounds like the LHS of the car was impacted). Failing that, I suppose its also worth checking that the hub and hub carrier are not also damaged. Not sure if you observed the toe while the wheel rotates? Curious to know what the answer is, please keep us posted.
VBC Wildfires
Old 11-28-2012, 12:27 PM   #765
stro3579's Avatar
Odin, if all of your hubs are ok. Try and loosen the srews on your rear toe blocks and possibly the front center blocks. Then try and reseat everything. I had this issue with buliding a brand new car and this seem to help. Keep us posted on your findings.
SEO by vBSEO 3.5.0
