Old 10-13-2012, 09:59 AM   #676
i was just curious if it might be too strong and break somethn',
Speed is 0.08 @6V /0.07 @7.4V and it's low profile.
Thank you.
ems
Eric Summers is offline   Reply With Quote
Old 10-13-2012, 10:51 AM   #677
Potoczak's Avatar
Trader Rating: 109 (100%+)
Thank you.
ems
It will work just be carefully when setting your end points.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 10-13-2012, 06:34 PM   #678
Dave Johnson grabbed TQ at the Fall Fiasco at Lou's Speedway in London Ontario Canada with his Wildfire in Stock 17.5. Unfortunately he smoked a motor in the Main.
Number 49 Lou's Speedway Canada, Honda House www.hondahouse.com
ElliotCanada is offline   Reply With Quote
Old 10-13-2012, 07:05 PM   #679
Potoczak's Avatar
Any chance on getting his setup posted??
Pete Potoczak
Old 10-13-2012, 08:02 PM   #680
Default VBC Wildfire
Just order a Wildfire. LHS wanted to know if it was 190mm or 200mm for ordering GT body. Any suggestion on body? Planning on running local club race - GT class either 21.5 or 17.5 GT.
Turbo911 is offline   Reply With Quote
Old 10-13-2012, 10:15 PM   #681
whiteflagwar's Avatar
It's a 190mm
If you run a 200mm body just get the hpi +5mm offset wheels, that is if they don't run a spec tire like jaco or sweep for the class.
whiteflagwar is offline   Reply With Quote
Old 10-13-2012, 10:57 PM   #682
Noted and Thanx a bunch.
ems
Old 10-14-2012, 08:04 AM   #683
Default Spare Parts
What spare parts are recommended to have on hand?
Are you better off just buying a second kit for parts?
Newby needs direction
Planning on running local club race - GT 21.5 or 17.5
Old 10-14-2012, 08:09 AM   #684
Trader Rating: 19 (100%+)
Steering knuckles and C-hub's seem to break the most often, Although i have broken a front arm as well. I would keep at 2 sets of each. Maybe more depending on your track and if anyone else would have spares you could use.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 10-14-2012, 12:53 PM   #685
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
I've broken C-hubs at least 2 times now... and not even at speed, I'm talking 30-40% speed going through a 180. I replaced mine with Xray 4 degree hubs for now.
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 10-14-2012, 01:27 PM   #686
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Does the xray c-hubs fit without modifications or other parts (is it a direct fit)?
Thanks.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 10-14-2012, 01:27 PM   #687
kuruption's Avatar
Thanks.
Fit into the A-arm is a bit tight... I recommend shaving down the A-arm a bit to allow freer movement.
Ray Sundland
Old 10-14-2012, 01:54 PM   #688
Not being mean why didn't we buy XRAY
anyway do they make Alum. hubs, or CA glue skim coat the kit ones(carefully) would help?
just curious.
ems
Old 10-14-2012, 02:03 PM   #689
Thanks.
Old 10-14-2012, 02:08 PM   #690
stro3579's Avatar
Trader Rating: 20 (100%+)
Is the plastic brittle on this car?
stro3579 is offline   Reply With Quote
