Old 09-30-2012, 12:46 AM   #631
apriliamille's Avatar
http://www.vbcracing.com/pages/support
Are you here to surf or fight !!!! -Apocalypse Now-
X-60CF, SCX60CF, X6 Cubed, Rebel 10, Hara d8, GT2, 4x4 sc: pondering
Beam, Protos, Wildhare, P.A.U., 3DHS, Aeroworks, RiteWing
Power and Fueled by TP, Graupner, FMA, Powermaster and xtrema
Controlled by Radiopost Sponsored by me and my passion
apriliamille is offline   Reply With Quote
Old 10-01-2012, 05:40 PM   #632
3D-Seth's Avatar
Trader Rating: 21 (100%+)
Hey guys,
Looks like I'll be getting my Wildfire tomorrow.
Just a quick question, since I'm fairly new to this on-road thing.
I will be running 17.5 Blinky at our local indoor carpet track. The track is pretty small (75 by 35 ish) and need a good starting point for gearing. Looks like the stock spur is 116t. Where should I start with a pinion?
Thanks!
Seth
3D-Seth is offline   Reply With Quote
Old 10-01-2012, 05:50 PM   #633
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
Originally Posted by 3D-Seth View Post
Hey guys,
Thanks!
Seth
Each motor is different, but I started around 44/94 and went up from there. Maybe start at 40/94 or similar and see what your temps look like.
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 10-02-2012, 06:54 AM   #634
3D-Seth's Avatar
Thanks!
Should start building tonight. A little excited, needless to say!
Old 10-02-2012, 04:20 PM   #635
sprintcarracer's Avatar
Trader Rating: 25 (100%+)
What brand spur gears will fit on this car. PRS and CRC don't fit.
sprintcarracer is offline   Reply With Quote
Old 10-02-2012, 04:29 PM   #636
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
The car uses Xray type spur gears. I know if you leave the plastic spacer thing off you can get a modified kimbrough on it.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 10-02-2012, 04:57 PM   #637
is it the xray offset ones or the other ones?
http://www.amainhobbies.com/advanced...r+gear&x=0&y=0
does anyone know if the RW spurs will fit?
https://www.speedtechrc.com/store/eb...d=392&id=11479
ill have mine to start building sometime this week. cant wait
Old 10-02-2012, 04:58 PM   #638
Trader Rating: 19 (100%+)
RW's do fit, they must be the xray offset style to work though. Unless you get rid of the spacer, but its there for a reason
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 10-03-2012, 05:15 PM   #639
kuruption's Avatar
The Xray offsets work, but then the gear is offset in the top deck a bit. I found that I could also use the RW Xray T2'007/008 spurs, before the offset.
Ray Sundland
Old 10-03-2012, 05:26 PM   #640
I just ordered a RW spur gear. I'll see how well it works.
Old 10-03-2012, 05:27 PM   #641
kuruption's Avatar
Anyone have any input into the best way to install and remove the spring clip around the axles used to retain the pins? I just got a set of swing axles and could not get the spring clips on at all, ended up just using head shrink and crossing my fingers...
Ray Sundland
Old 10-03-2012, 05:31 PM   #642
seth556's Avatar
Trader Rating: 37 (100%+)
I used a Kimbrough although I had to sand down the spacer a tad. But once you do that you can fit any of them.
seth556 is offline   Reply With Quote
Old 10-03-2012, 06:19 PM   #643
Hi Kuruption,
Are you talking about the new double joins uni? If yes I do found those spring clips too tight. What I did was enlarge those clips a little bit and it will be much easier to install.
DanDan is offline   Reply With Quote
Old 10-03-2012, 09:04 PM   #644
when you get it, if it fits would you share the part number and where you got it so i can order some as well?
good luck to the qualifiers tomorrow (thursday)
Old 10-03-2012, 09:07 PM   #645
kuruption's Avatar
Nexus Racing... search for 'RW' and the spurs will come up.
But I recommend trying your LHS first.
Ray Sundland
