Old 08-19-2012, 06:41 PM   #361
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Originally Posted by Ron Goetter View Post
The car comes with F00 block for the front and a R30 rear. Which yields 0* arm sweep in the front and 3* rear toe. The option blocks are F05, F10, R20 and R25.
The car is 189mm wide front and 188mm in the rear.
Thanks for the quick reply.
Next question, how do you reduce the track width (at hinge pins and not hexes)? Are there optional split blocks that are narrower?
And is the green alloy parts avail yet? and from where?
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 08-19-2012, 06:46 PM   #362
Odin544's Avatar
Trader Rating: 93 (100%+)
Originally Posted by DirtyDog3375 View Post
Just wondering about the optional suspension blocks:
does anyone know the spacing (for track width adjustment)
what comes in the kit (frt and rr)
Also, anyone tried the flex chassis yet? and is there any pics avail?
posted on VBC Crew facebook page dated Aug 3rd
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 08-19-2012, 06:52 PM   #363
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
I'm sure there will be option blocks for that at some point in the future but as of now I don't believe they have anything for that.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 08-19-2012, 06:54 PM   #364
Trader Rating: 19 (100%+)
There are not optional split blocks yet, however, any of the tamiya blocks bolt up, Im not sure about the split ones but the solid ones do and it looks like the split blocks would work. (Edit: the split blocks bolt up as well!)
The green parts are not available yet, but should be soon.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 08-19-2012, 06:54 PM   #365
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Only using hexes.
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 08-19-2012, 07:37 PM   #366
Thanks for all the replies. Much appreciated. I will check out the FB page when I get home from work (stupid workplace blocks!)
Old 08-19-2012, 07:57 PM   #367
Odin544's Avatar
Has anyone played around to see how small of spur will fit? Ran a 96/51 on my TC6 last year. Would like to avoid sanding on the top deck if at all possible. Maybe a 92/47?
TriCitiesRC.com
Old 08-19-2012, 08:01 PM   #368
S.Stew's Avatar
I ran a 92 spur and the smallest pinion I could fit was a 44 and still have proper mesh.
92/47 should fit.
S.Stew is offline   Reply With Quote
Old 08-19-2012, 08:02 PM   #369
Trader Rating: 23 (100%+)
i ran 68/37 48p yesterday works out around 90/49 in 64p. minor bit of sanding needed on the top deck just to widen it that little bit for the pinion. If you have the hudy narrow pinions, i think it will fit without any modifications.
poop is offline   Reply With Quote
Old 08-19-2012, 08:06 PM   #370
i worked out min and max teeth for 48p
min 103 and max 116
64p (if my calcs are correct)
min 138 and max 154
so 92/47 = 139 teeth so it should fit
Old 08-19-2012, 08:28 PM   #371
Odin544's Avatar
Awesome. Thanks guys.
TriCitiesRC.com
Old 08-20-2012, 03:43 AM   #372
The Teacher's Avatar
Trader Rating: 47 (100%+)
Ron Goetter, thanks for the offer but unless you have a new set of hands and a can of driving skillz I don't think you can help See you guys Sat....
The Teacher is offline   Reply With Quote
Old 08-20-2012, 06:38 AM   #373
The green parts are in stock at Team CRC as are the double joint CVD kits. They might not be on the website yet, so give us a call. We have them.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 08-20-2012, 07:44 AM   #374
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Damn and I just sent in my order last night. Next order I will get a few green pieces I want.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 08-20-2012, 08:41 AM   #375
Kwikvdub's Avatar
Trader Rating: 90 (100%+)
Send a message via AIM to Kwikvdub
Does the kit come in a "Green" edition??
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
