Old 08-10-2012, 05:13 AM   #301
NolanP's Avatar
Dumb question for those of you who leaked from the diff....did you tighten it using a star pattern at equal tightness levels? or just go around in a circle?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 08-10-2012, 05:51 AM   #302
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Thumbs up
Originally Posted by schreff View Post
LOL! You did get one. That's funny man. I finished mine last night. I was too lazy to take a pic and my wiring isn't exactly Larry or Goat style.
Maybe I'll convince Goat to clean it up for me. ROAD HOUSE!
That might not work on the goat anymore.
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 08-10-2012, 08:39 AM   #303
schreff's Avatar
Send a message via AIM to schreff
That wasn't a food reference. That was a Family Guy reference.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 08-10-2012, 08:51 AM   #304
schreff's Avatar
Nolan,
One little tip that might help...
Since I've been racing a lot of 8th scale and those diffs love to leak too, I tend to use different silicone sealants on gear diffs. I've been using Yamabond #5. It dries as a rubber type seal in addition to the paper seal and no leaks what so ever.
It's also easy to remove when you open the diff up as it's not permanent.
I tightened mine in a star pattern and didn't put any Yamabond on it so I'll find out tomorrow if it's going to leak. They usually seep a little, no matter what brand, then it stops once the overfill is gone.
-Jason Schreffler-
Old 08-10-2012, 09:19 AM   #305
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Does anyone have the stock spring weights in a pound rating? Are they 16lb, 10lb etc. Looking to try some other springs other than the White and Reds in the kit but was looking for a standard lb rating as to compare to like Associated weights.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 08-10-2012, 10:48 AM   #306
schreff's Avatar
Brian, if I have my calculations right...
VBC Green = 2.8kgf/mm = ~15.5lb
VBC Red = 3.0kgf/mm = ~16.3lb
VBC Orange = 3.1kgf/mm = ~17.3lb
VBC White = 3.3kgf/mm = ~18.3lb
There can be some differences depending on if the springs are linear or progressive and the number of coils. These are just ball park numbers considering the conversion tool I used. They can be off give or take .5 lb.
-Jason Schreffler-
Old 08-10-2012, 03:46 PM   #307
Ghost.
Kane-o is offline   Reply With Quote
Old 08-10-2012, 04:36 PM   #308
wyd
Tech Legend
wyd's Avatar
You are the man. Thanks
Old 08-10-2012, 05:48 PM   #309
olhipster1's Avatar
Trader Rating: 91 (100%+)
Send a message via Yahoo to olhipster1
Someone is getting closer!
big smile dudes!
it's on a little small brown truck somewhere midwest.
watch out guys...the infamous Schreff is back on rubber slicks...
we will have a plethora of information on this thread.
----I always wanted to use the word!! (plethora)
RU....you know you need something different...it's time for a little gun metal goodness.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 08-10-2012, 05:58 PM   #310
Kwikvdub's Avatar
Trader Rating: 89 (100%+)
Send a message via AIM to Kwikvdub
Alex Valdes
TQRacing / 360 v2 RC Raceway
Kwikvdub is offline   Reply With Quote
Old 08-11-2012, 03:17 PM   #311
schreff's Avatar
Well guys, my first official race day on the Wildfire is in the books and I couldn't be happier with how things went.
When I built the car, I basically did most of the kit setup with some of my own very minor changes. I used Losi 40wt oil in the shocks, had about 50% rebound, and did not drill the caps. I will do that next time to try it further. I also ran the car with the bars disconnected as our asphalt track is very tight with a lot of low speed corners. It's basically an asphalt carpet track if you can imagine such a thing. The rest of the setup, including springs, pistons, arm spacing, roll centers, and camber link positions were all kit setup. I also did not run ECS style front shafts as I have none right now.
First time on the track, it took me a little to get back into the swing of things with not running a touring car for close to 5 months. The first 2 hot laps, I nailed a chicane at full speed (bonehead move) and sent the car flying. I basically ruined the body in a matter of 5 minutes. The best part, not 1 broken part! This car can take some crazy hits. Heck, in one qualifier, I hit another car that was spun on the straight and ripped the entire rear suspension off the other car. My car just had the body all punched in and I pulled it off thinking mine was broke too. Instead, just a screw pulled out of a rear body post, which was my fault for not putting a long enough one in anyway.
After I was done driving like a moron and wrecking the car, I got into the swing of driving again and WOW is this car lethal. It's smooth, carries high speed corners awesome, and transitions very quickly in low speed corners. It's also very easy on tires and very consistent through a run. I changed very minor items throughout the day (mainly camber and rear camber link position) and each change was subtle enough to make the car a little quicker, but not sacrifice drive-ability. The guys at my local track definitely saw how good the car was with "out of the box" stuff and that's a huge selling point.
The next time I hit the track will be on carpet and I'm really looking forward to it. I'll definitely learn some good stuff there and post info for folks running on carpet. VBC and CRC have a winner here and it's going to be an awesome winter season. It may even make me stop running offroad for a while and get me to hit some big TC races.
-Jason Schreffler-
Old 08-11-2012, 04:31 PM   #312
MikeXray's Avatar
Trader Rating: 72 (100%+)
I love reading sponsored guys first run with a new car posts, this one did not disappoint either car is Lethal
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-11-2012, 04:31 PM   #313
seth556's Avatar
Trader Rating: 37 (100%+)
Just finished building the car, everything seems to be very good except the spur and pinion setup. I fitted a Kimbrough spur which clears fine but I realized while fitting the motor that it's going to be a bitch to tighten one of the motor screws but that's not that big of a deal. The main problem is that I am using the Epic Trinity pinions and they rub on the top deck (both sides), should I start using PRS or any other narrow pinions or just sand the inside of the top deck so the Epic pinions fit?
seth556 is offline   Reply With Quote
Old 08-11-2012, 04:49 PM   #314
olhipster1's Avatar
Default Wow
I saw, held and I witnessed what this car has.
Must say I've never seen a car come alive so quick, it's an eye opener to see Screff take the car with confidence.....once he saw the car was durable he started to push it.
Car took turns like it had wings......this is my next ride period. The quality is shown throughout the car.
Way to go VBC
CAUSE and EFFECT
Old 08-11-2012, 04:50 PM   #315
303slowdown's Avatar
Trader Rating: 19 (100%+)
This is the same on almost every car when running blinky. I have 417, xray, robitronic, all the same with the motor screws. What you do is tighten the front screw to set mesh then take top deck off and pull layshaft up to tighten other screw.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
