Old 08-02-2012, 10:35 PM   #226
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by gijoe64 View Post
VBC will be sell a green alum parts set for the wildfire soon.
where is the all pink 'Dumper Edition'?
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-03-2012, 06:23 AM   #227
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 08-03-2012, 07:17 AM   #228
Trader Rating: 24 (100%+)
Send a message via AIM to Max K
Originally Posted by poop View Post
Anyone know what the kit gear diff oil wt is?
putting mine together now and it's looking sweet
Thanks!
3000cst
RC America - XRAY - HUDY - Trinity - ORCA - Sanwa - ULTI - PROTOform - MaxFX - Slapmaster Tools - ApexRC - SXT
Max K is offline   Reply With Quote
Old 08-03-2012, 08:00 AM   #229
The Teacher's Avatar
Trader Rating: 47 (100%+)
dumper, how do you get to the Flex chassis on the CRC site? Trying to get one but can't find it.
Have any of you guy played around with the gear diff up front? If so what lube were you using and what did it do for the car...?
The Teacher is offline   Reply With Quote
Old 08-03-2012, 09:15 AM   #230
It's up there now. My announcement was before the web guy was ready.
Old 08-03-2012, 09:20 AM   #231
http://www.teamcrc.com/crc/modules.p...prodID=7719406
Old 08-03-2012, 10:07 AM   #232
gijoe64's Avatar
Trader Rating: 27 (100%+)
Dumper, what suspention mounts should I use for carpet? E10, E5? I would like to get them on order this week.
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 08-03-2012, 11:24 AM   #233
I have been switching back and forth between a spool and a gear diff. I used Cleaning putty in the diff. It was defiantly faster but a lot harder to be consistent with. The spool up front is a lot more forgiving and easier to be consistent with.
Old 08-03-2012, 12:42 PM   #234
There is an E20, E25, and E30.
E20 = 2.0 degrees of rear toe
E25 = 2.5 degrees of rear toe
E30 = 3.0 degrees of rear toe
The car comes with the E30 which is what most people use. If you feel like you need less to fit your driving style, then you will need the other blocks to do so.
Brian
Old 08-03-2012, 01:34 PM   #235
gijoe64's Avatar
Brian
Thanks for the information!
Raymon Robinson
ARC, LRP Go Blue!!
Old 08-03-2012, 02:03 PM   #236
Max K, cool thanks. Practicing on the rug this weekend wanted to try that along with some sway bar changes and front width changes. Going to try the putty but last time I built a diff with that stuff I got more on me than in the diff....
Old 08-03-2012, 02:44 PM   #237
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Hey Teach what brand spur gears are you using? I have a 95 tooth on mine but it don't have holes big enough to get the gearing I need. What a total pain in the ass.
Also are you going to Middle River to practice on Sunday? If so I can have my car ready by then and can meet ya and burn a few packs thru.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 08-03-2012, 03:23 PM   #238
wyd, I use xray spur gears (96 tooth 64 pitch), but it's still a pain to get to the motor screws....haven't found a good solution yet The plan is to go to MRH, I'll pm you Sat and let you know for sure...
Old 08-03-2012, 03:45 PM   #239
wyd
Tech Legend
wyd's Avatar
Ok. Sounds great.
Old 08-03-2012, 06:08 PM   #240
wyd
Tech Legend
wyd's Avatar
Ok the car built easily and the directions are excellent. Love the car so far but one thing that totally sucks and since I been away for so long is the spur gear problems and running 17.5 blinky.
I didn't know I would need a gear with big holes into it to get to the damn motor screws and even though our shop has a few hundred gears not one damn spur gear has the big holes I need so now I need to waste time ordering a gear that fits. This has me grounded or I would be running tomorrow. Total pain in the ass to say the least. Now once I find the right gear then this will not be a problem ever again. Just mad now as I wanted to race it Sat but might get Sunday practice in if I can find a gear or the shop I'm going to practice at his the right style of gear.
It is a small thing but now I know. Everything on the car was pretty much perfect fit and finish. Just very light sanding on the steering knuckles to fit so no binding and then a little sanding on the caster block for the new front ESC type driveshafts (whiich I already new about having to do) so no problems. All in all one of the easier touring car I put together in last 10 years.
