Old 07-10-2012, 04:43 PM   #136
Trader Rating: 24 (100%+)
Send a message via AIM to Max K
Originally Posted by rdlkgliders View Post
where are you guys getting spare parts? does the car use tamiya full length brackets (suspension mounts) on the front and rear suspension or full length blocks and split block combo like the xray? are there optional brackets for tuning ? if so where can I get them
Optional suspension blocks will be available soon! CRC should have them soon. But for now Tamiya blocks bolt right on.
I apologize if this has been answered before but I couldn't find it. Anyway, does this car come with Standard or Metric type of screws?
Metric
RC America - XRAY - HUDY - Trinity - ORCA - Sanwa - ULTI - PROTOform - MaxFX - Slapmaster Tools - ApexRC - SXT
Max K is offline   Reply With Quote
Old 07-10-2012, 05:20 PM   #137
Trader Rating: 54 (100%+)
When will this car be available in the US? Seams the date has changed
Jamison R is offline   Reply With Quote
Old 07-10-2012, 07:31 PM   #138
Should be available July 19 from Horizon. CRC Has them now
Old 07-10-2012, 11:36 PM   #139
MikeR's Avatar
Trader Rating: 14 (100%+)
Thank You, I looked on the crc website and did not see any blocks available yet. I will keep an eye out.
Metric
www.exotekracing.com
VBC new 1/10 touring car, Wildfire.-dsc_0791__16102_zoom.jpg
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 07-10-2012, 11:59 PM   #140
Trader Rating: 15 (100%+)
Default Parts
On the inner camber mounts there are four positions whow are they nubered
AARON YOUNG is offline   Reply With Quote
Old 07-11-2012, 06:42 AM   #141
Default In stock at CRC
The VBC Wildfire is in stock at CRC and shipping now!!!!!!!!!!
www.teamcrc.com
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 07-11-2012, 12:25 PM   #142
eevul's Avatar
Metric
Thank you!
eevul is offline   Reply With Quote
Old 07-11-2012, 03:24 PM   #143
Old 07-12-2012, 05:09 AM   #144
I would start with my setup from reedy. Me and Dave were running basically the same setup and it worked very well!
Front Setup:
3rd from most inner hole
outer most hole on lower shock mount
40wt oil
hole drilled in shock cap
25% rebound
1.24mm swaybar
xray ecs drive shafts
.5mm wheel spacer
2mm spacer in back of arm for wheel base thick up front
2mm shim under inner link
0 shims under arm mounts
VBC Pink spring
-2 camber
6 droop
5mm ride height
Gear Diff 300,000
Rear Setup:
3rd front inner most hole
35wt oil
25% rebound
1.20mm swaybar inner mount position on arm
2mm shim under outer link
all shims forward on rear wheel base
0.5mm shim under front and rear block
VBC Blue spring
-2 camber
2 droop
5.25mm ride height
Gear Diff 1000
Took 2 screws out of top deck behind spur gear (helped rear end flex more)
Protoform LTCR Body
body roof height just slightly higher than ROAR Rule
I would start with a spool in the front tho. Thats the only thing I would change to start
Hello,
Will Xray ecs drive shafts fit directly ?
P.S.: the car is great out off the box, very good quality and easy to drive fast !!
shiver750 is offline   Reply With Quote
Old 07-12-2012, 04:51 PM   #145
Trader Rating: 23 (100%+)
any of you guys having trouble with the diff gears stripping?
poop is offline   Reply With Quote
Old 07-12-2012, 07:27 PM   #146
Originally Posted by shiver750 View Post
Hello,
Yes the Xray ECS drive shafts will drop right in. You need to cut away a little bit of the caster block tho.
VBC new 1/10 touring car, Wildfire.-img_2013.jpg
Old 07-13-2012, 06:16 AM   #147
That is not something we have seen.
Old 07-13-2012, 10:32 AM   #148
The Teacher's Avatar
Trader Rating: 47 (100%+)
Has anybody found spring rates for the kit springs?
Max K, thanks for the pic of the caster block made the mod to mine last night works like a charm....
poop, did you sand the back sides of the gears in the gear diff? Maybe you sanded too much...?
The Teacher is offline   Reply With Quote
Old 07-14-2012, 03:39 PM   #149
cheers for the feedback on the diff gears. my friend races in asia and there have been reports of them stripping quite badly to the point people drop an xray diff in there and ditch the VBC one completely. just want to confirm before commiting to this car
Old 07-15-2012, 12:04 PM   #150
I have been running my car with a 4.5 in it since reedy. I haven't had any problems with the gears stripping in the diff.
