Glue on Sorex tire - best way to get it off? >
Old 03-03-2012, 08:45 PM
Suteki's Avatar
Default Glue on Sorex tire - best way to get it off?
Being the horrible tire gluer I am, I got some ca glue on my finger as I was gluing the tire to the rim and consequently left a nice gluey finger print on the tire rubber itself.
Is there a way of getting that glue off? ie. a quick dab of acetone? Or should I just leave it and hope it gets etched away during racing?
Suteki is offline
Old 03-03-2012, 08:55 PM
sand paper
iwkyb is offline
Old 03-03-2012, 09:56 PM
Suteki's Avatar
Originally Posted by iwkyb
sand paper
Won't ruin the tire?
Suteki is offline
Old 03-03-2012, 09:59 PM
lightly scrub the glue off
iwkyb is offline
Old 03-03-2012, 10:03 PM
Suteki's Avatar
Cheers.
Suteki is offline
Old 03-03-2012, 10:35 PM
Mike Mandio's Avatar
Acetone will remove CA glue without damaging the tire.
Mike Mandio is offline
Old 03-03-2012, 11:19 PM
Nail polish remover has acetone. I use it for ungluing my fingers from each other, and it also removed some long-dried CA that was dripped onto my setup board.
I have no idea if acetone or nail polish will damage rubber. If you care about the tires, you should probably test it on an old set first.
-Mike
grippgoat is offline
Old 03-04-2012, 01:22 AM
Suteki's Avatar
-Mike
I know acetone won't damage the tire, just wondering if it will effect it's performance in the longer run.
Sand paper will do the trick as I run asphalt which is pretty much going to do the same thing but acetone I would think would be quicker and easier. Just want to make sure it's not going to effect the tires over all grip levels even if I am only doing a spot or two.
Suteki is offline
Old 03-04-2012, 03:35 AM
Trader Rating: 38 (100%+)
Not all. Your better off with straight acetone. It will work better/quicker.
or8ital is offline
Old 03-04-2012, 03:46 AM
Suteki's Avatar
Yeh some newer nail polish is 'acetone' free. What's the fun in that?
Suteki is offline
