WANTED - Dyno Data
WANTED - Dyno Data
I'm looking for someone who would like to work with me to complete some specific brushless motor flywheel dyno tests. Initially I just want to look at one motor say a 17.5. Testing would involve runs with mechanical timing (0,10,15,20,...), and similar runs with electronic timing.
I will use the data to build as a start to build the motor library in RC Crew Chief. If you want to see what I plan to use it for watch this Youtube video.
http://www.youtube.com/watch?v=n4OKO...eature=channel
Post or PM if you are interested.
Dyno
I use a prop dyno from 1989 that we made when I worked at "Redline". It was built for brushed motors but I have changed it over for Brushless.
I have also played with the "Eagle Tree" datalogger. You may want to look at that. It will give you a lot of usefull data. The key for me was to get the "on track" amp draw. One you have that you can dyno motors to see how they perform at that load.
Steve Dunn
Indianapolis, IN
Steve Dunn
Indianapolis, IN
Steve Dunn
Indianapolis, IN
Steve Dunn
Indianapolis, IN
Could you send me a test file to try out?
I'll have a look at the turbo dyno and see if it would work for what I am trying to do. I'm already set up to handle flywheel data so that would be my preference.
Was involved in the Sentry Dyno thread a couple years back and John sent me a couple files which are the basis for what I have so far. I've tried to contact him again but no response.
