Old 01-18-2005, 01:32 AM   #16
Cole Trickle's Avatar
Originally posted by SalvadoriRacing
there is no risk of damaging the pack by setting the trickle current down to 50mAh.......
if you let your pack sitting after peak during 1 hour it will charge only 50mA more.....
and I think nobody leaves a charged pack sitting for that long...
You might be right. On the other hand, almost every battery matcher recommend disabling the trickle charge.
I dont have the 16x5BL (I have the v6). But according to the manual, the trickle charge on the BL is fixed at 150 mAh.
Basically, trickle charge after the regular charge, is overcharging the pack. That Indi charger pushes the pack far, with the VSEC charge, so chargin it further is something I wouldnt recommend.
From my own experience, I had a pack of Sanyo 3000 HV, which didnt last long. I had a charger wich trickle charged. The pack wasnt left on it a lot... The pack could have died for other reasons, but it's the only pack I've ever had, that lasted so short...
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 01-18-2005, 09:10 AM   #17
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
you're right cole.....
It was my bad......
To avoid trickle charging with the 16x5BL you should set the battery capacity to 50mA, then the software disable trikcle charging because 150mAh is too high for a 50mA batt.....
even for 3300 packs you can set the batt capacity to 50mA, this setting is only to able or disable trickle charging after peak....
Salvadori Racing
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
FS: Duratrax ICE Charger, Great Planes Triton Charger, & MRC Power Supply wrxnfx R/C Items: For Sale/Trade 15 08-20-2008 10:33 AM
*** Triton Jr. Li-Po Charger *** raydog R/C Items: For Sale/Trade 18 07-26-2008 05:19 PM
triton charger dezertridr57 R/C Items: For Sale/Trade 2 05-22-2007 12:55 PM
Triton Charger TC3SFR0MHE77 R/C Items: For Sale/Trade 0 03-01-2005 06:02 PM
Triton Charger huskerfreak R/C Items: For Sale/Trade 2 02-15-2005 03:11 PM
SEO by vBSEO 3.5.0
