Old 06-24-2002, 11:20 AM   #1
Default Voltage Threshold?
I just purchased a new Novak Millenium Pro charger and some new Integy Sanyo 3000HV packs. What should i set the voltage threshold at on this charger? Should I change the voltage threshold when the packs have a few cycles in them? Also, what amperage should i charge them at? I will be using them in stock and modifed touring. Also, what do you guys set the voltage threshold and amp charge rate at for 2400 and 2000 packs? Any info and help is appreciated.
James Nguyen
James Nguyen is offline   Reply With Quote
Old 06-24-2002, 01:21 PM   #2
Joe's Avatar
I use the NiMH2 mode on my mill pro for my HV's, it works quite well. I charge all my packs at 5 amps and for NiCD I use 12mv/cell, or 72mv/pack.
Joe is offline   Reply With Quote
Old 06-24-2002, 03:45 PM   #3
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
i'm no pro, but i go with 10/cell 60/pack for nicads. the nimh mode doesn't have an adjustable threshold, i don't think. for charge rate:
2000's - 4.5a
2400's - 5.0a
3000's - 5.0a
but what do i know?
seaball is offline   Reply With Quote
Old 06-24-2002, 10:49 PM   #4
Simon K's Avatar
I charge my 3000HV's at 5.5a with a 70mv peak. I use them in stock.
Simon K is offline   Reply With Quote
Old 06-25-2002, 02:24 AM   #5
Here are the settings I use with the Millenium Pro
Sanyo 3000Nimh HV I use linear mode - 5 amps charge - Voltage threshold 12mv/cell (72mv per pack)
Panasonic 3000 Stock - Nimh2 mode - 4.5 to 5 amps charge
Sanyo 2000
Linear mode - 5 amps charge - Voltage threshold 14mv/cell
Reverse Pulse mode - 5 amps charge - Pulse 12ms - Voltage Threshold 14mv/cell
Sanyo 2400
Linear mode - 5 to 5.5 amps charge - Voltage Threshold 14mv/cell
Hope it helps,
Ralf is offline   Reply With Quote
NiCD/NiMH Voltage vs Lipo Voltage bryanleec Radio and Electronics 10 02-06-2008 05:08 PM
Integy 16x5v6 discharge voltage threshold? Bob Nilsen Electric On-Road 2 04-03-2004 03:12 AM
voltage threshold fasterdanu Electric On-Road 5 02-22-2003 12:59 AM
SEO by vBSEO 3.5.0
