Old 10-30-2013, 12:14 PM   #391
oeoeo327's Avatar
Trader Rating: 70 (100%+)
Originally Posted by InspGadgt View Post
Pick your favorite color...if you already have a 1/12th scale then I would say you might want to get the same brand WGT car as your 1/12th as many parts will be interchangeable.
This is very good advice... Served me well supporting 2 cars (CRC at the time) with one set of spares between them.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 10-30-2013, 12:39 PM   #392
I run a couple of CRC cars as well...with both having the slider pod now that means a lot less spare parts to carry with me as I don't have to carry a crap load of rear axle ride height adapters When the new F1 comes out I plan to run that as well
Old 10-30-2013, 02:08 PM   #393
Pulse_'s Avatar
ok then it would be an Associated 10R5.1.. I think!
anything particular to know about this car?
https://www.youtube.com/channel/UC1CAwFfuz1K3chBSVpIlSew
Pulse_ is offline   Reply With Quote
Old 10-30-2013, 11:21 PM   #394
Don't hit the boards hard and alot, the CF bumper and front of the main chassis will crack and tear out the mounting holes. Other than that, its a pretty good car. Esc mounting and wiring may be a pain.
RoyU is offline   Reply With Quote
Old 11-02-2013, 08:40 AM   #395
Pulse_'s Avatar
I had no problem for esc mounting and wiring on the 12r5.2 but the lipo removal sure is a pain.
Main concern is the built quality, simple layout, easy to set up
Old 11-02-2013, 12:21 PM   #396
Still Bill's Avatar
OK...I may have to get an F1 then...If Burt has one...LOL
All CRC of course!
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 11-02-2013, 06:44 PM   #397
Trader Rating: 26 (100%+)
Hi guys, sorry if this seems like a silly question, I'm trying to find some wheels/tires for my old rc10l (235mm) and was wondering if the JACO World GT Specs Tires Lilac Front and Rear wheels would work/fit? Are they the same size (diameter and width) as the OLD wheels that I have.
Thanks for any help
Daniel
$$$... is offline   Reply With Quote
Old 11-02-2013, 06:59 PM   #398
howardcano's Avatar
Trader Rating: 35 (100%+)
Thanks for any help
Daniel
Yes. The wheel diameters are slightly larger, and the front wheels have less offset than the original RC10L wheels, but they still work fine. The compound might be a bit hard, depending on your track surface.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 11-08-2013, 10:08 AM   #399
Pulse_'s Avatar
maybe someone can help me here
I'm looking for a 10r5.1 and a UK driver is selling this one
is just the chassis different from a standard 10r5.1? It's made by fibre lyte but I have no more infos
Old 11-08-2013, 11:46 AM   #400
Looks like a 10R5 with an aftermarket chassis and the pod from a 12R5.1. The 10R5.1 has dampener tubes instead of a side shock, and shares its rear pod with the 12R5.2. The front suspension is also the older version- threaded inserts in the lower arms. Definitely not a 10R5.1.
Serzoni is offline   Reply With Quote
Old 11-08-2013, 11:59 AM   #401
Pulse_'s Avatar
thanks! I had some doubts so I'm glad I asked the question here
Old 11-14-2013, 08:10 PM   #402
NutDriver's Avatar
Trader Rating: 14 (100%+)
I was hoping that I could get some input on preferred 1s ESCs. I have a Hobbywing 1s, but was hoping to get another ESC that costs less. Opinions?
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 11-14-2013, 08:55 PM   #403
Still Bill's Avatar
Scott
Scott,
I have an older Hobbywing V2.1 1S in one WGT (asphalt) that performs really well.
You might check around for a used HW V2.1 1S. It was replaced by the HW V3.1 1S that some racers likely 'just had to have'.
Bill
Old 11-15-2013, 04:46 AM   #404
if you run only blinky, the Hobbywing Just Stock is an option worth considering. They are much smaller than the boost capable versions and they are super inexpensive. I think CRC sells the Just Stocks for under $70, which is an amazingly low price for a good solid speedo. One drawback (a minor one), you'll probably need a booster if you run 1cell with the Just Stock speedo. Luckily good boosters are small and light and available at low prices too.
vafactor is offline   Reply With Quote
Old 11-15-2013, 07:35 AM   #405
NutDriver's Avatar
I was planning on running Blinky with a 13.5 and 1s.
Thanks for the info Bill and VA.
Bill, can you direct me to a baseline setup for the CRC 10LE?
USVTA member #111
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 07:05 AM
World GT? brettness37 Electric On-Road 12 11-01-2010 10:11 PM
Xray X10 World GT Car PitNamedGordie Electric On-Road 262 04-22-2010 03:18 AM
SEO by vBSEO 3.5.0
