Old 01-29-2013, 07:02 AM   #316
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thumbs up Roar Carpet On-Road Regional Feb 10, 2013
If you're in Socal, if not then ROAD TRIP
Let's bust out those WGT's
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-23-2013, 04:34 PM   #317
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Okay, I'm almost done building this WGT. I said it was going to be a slow build. All I need is to paint and mount the DB9 body.
My rear pod top plate originally is the stubby one with the shock ball end hole behind the damper tube ball end holes. Because I have changed to an inline battery position, the shock needs to mount more forward like the newer WGT cars. I looked in my parts bin and found rear pod top plate from a BMI 12R that has the shock mount further forward. The screw holes match the Speedmerchant pod but just only the 1st two holes because the hole spacing (front to rear) is different on the Speedmerchant than on the BMI. Side to side (Left to right) the hole spacing and position of the plate matches. So its only mounted on the pod with just two screws instead of four. Will this hold? Is the additional two screws necessary to mount the rear pod top plate?
I would order the proper part from Speedmerchant but its a $9 part and they charge $9 to ship. If someone has the part to sell and would ship for the cost of a postage stamp, I would appreciate it.
YR4Dude is offline   Reply With Quote
Old 02-23-2013, 04:44 PM   #318
it will work just fine with just 2 screws holding the top pod plate on. Some of the newer cars are made that way.
vafactor is offline   Reply With Quote
Old 02-26-2013, 01:24 PM   #319
YR4Dude's Avatar
Thanks! I just looked up those other cars you talked about and noticed the Rebel 10 is like what you said.
A question about tires:
Are they to be cut down to a specific diameter for best performance or does the spec not allow tire cutting?
Old 02-26-2013, 03:39 PM   #320
Wink
Seriously ?
I start mine at 53mm Fr & Rr
Smaller is better when grip comes up
Old 02-26-2013, 03:43 PM   #321
Trader Rating: 15 (100%+)
WGT =/= VTA
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 02-26-2013, 04:28 PM   #322
YR4Dude's Avatar
Originally Posted by RedBullFiXX View Post
Seriously ?
Originally Posted by LloydLoar View Post
WGT =/= VTA
Am I missing something about the rules for WGT?
Old 02-26-2013, 05:00 PM   #323
oeoeo327's Avatar
Trader Rating: 70 (100%+)
You're not missing anything - it's just that the inside joke about WGT is that it's the "VTA" of pan car racing. That said, all of the usual pan car setup tips should be employed in preparing your car to compete, the first of which involves cutting down your tires to a reasonable size. 53mm is a good size to start with for carpet, and if you get the chance to race WGT on an outdoor track, I'd recommend 55mm as a starting tire size, maybe a little taller if grip is low.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 02-26-2013, 08:05 PM   #324
avs
avs's Avatar
"Son, I have met WGT and it is no VTA."
(said in the voice of the texas congressman VP candidate, who i can't remember, but used that line against George Bush's VP candidate whose name i also can't remember. not memorable except he mispelled potatoes?)
Tony Shimko
avs is online now   Reply With Quote
Old 02-26-2013, 08:40 PM   #325
WGT>VTA
Old 02-26-2013, 09:46 PM   #326
Still Bill's Avatar
Now, who is misspelling...
Various celebrated quotations...
I have made good judgements in the Past. I have made good judgements in the Future.
Dan Quayle
People that are really very weird can get into sensitive positions and have a tremendous impact on history.
Dan Quayle
The American people would not want to know of any misquotes that Dan Quayle may or may not make.
Dan Quayle
The future will be better tomorrow.
Dan Quayle
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 02-26-2013, 10:12 PM   #327
CypressMidWest's Avatar
Best thing about WGT tires is that once you hit the "sweet spot" as far as diameter is concerned, they are STELLAR until you see rim where there's supposed to be foam. My best (TQ) run at the 4th leg of the Midwest grand slam series was started on 1.99" (sorry about my pesky imperial measurements). When I was done the very outside and inside edges of the fronts were bare plastic, and there were some small blank spots in the center as well.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 02-27-2013, 06:58 AM   #328
I've never heard the VTA WGT comparison reference before
It's odd, seeing as how WGT are quite often one the quikest cars at the races
WGT is a supa fun, easy, low maintenece car to run
Sauce tires, rotate fronts each run, rinse, repeat for weeks, as the spec Lilacs last a long time
Old 02-27-2013, 07:23 AM   #329
CFR
CFR's Avatar
What do you 'rinse' with?
CFR is offline   Reply With Quote
Old 02-27-2013, 08:03 AM   #330
oeoeo327's Avatar
Originally Posted by InspGadgt View Post
WGT>VTA
In reality, this is true... These cars are quick, and a blast to drive - but certainly easier to control when compared to a 1/12 scale pan car.
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 06:05 AM
World GT? brettness37 Electric On-Road 12 11-01-2010 09:11 PM
Xray X10 World GT Car PitNamedGordie Electric On-Road 262 04-22-2010 02:18 AM
