Old 12-13-2012, 01:14 PM   #241
briankstan's Avatar
I purchase some of the WGT Jaco tires, I can't even drive them because the balance of the car gets completely out of wack. the fronts have so much more grip than the rears and the car just wants to spin out. change to the BSR's and it's Dialed.
I've ran several sets of the BSR's purchased at different times with no issues, I bought the Jaco's because of the price, but if I get unpredictable compounds with them It's just wasted money. From what I have found the Jaco's are subject to be different compounds even though they are mounted to the white wheel and tagged Lilac.
www.slmini-zstore.com
www.saltlakemini-z.com/forum
www.howfastareyou.com
briankstan is offline   Reply With Quote
Old 12-13-2012, 01:21 PM   #242
303slowdown's Avatar
Trader Rating: 24 (100%+)
Ive ran many sets of jaco wgt tires and have had no issues. You might have to change your setup . The wheels are softer so they flex more ,i think thats why you have more steering
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 12-13-2012, 01:33 PM   #243
CypressMidWest's Avatar
Originally Posted by AdrianM View Post
For Jaco Lilac Spec tires the White Rim=The Purple Stripe on BSR Lilac Spec tires, i.e. Only Lilac foam is mounted on Jaco white rims.
As a race director, I require that the tires have the purple stripe at my races. While it is true that Jaco only mounts lilac foam on the white wheels, the lack of the identifying stripe on the tire makes it all to easy for an unethical racer to strip, and remount a different compound.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 12-13-2012, 01:34 PM   #244
Green Machine!'s Avatar
Send a message via MSN to Green Machine!
I changed from BSR to Jaco, just to experiement, since I'm new to WGT. I stumbled upon two things. Mainly by accident. I run the Serpent S100LT and the BSR wheels fit loose over my rear axle hub and I have to be careful not to bind up the front wheels when I tighten the nut. The Jaco's fit like a hub-centric wheel on the rear (nice and snug) and the front wheels tighten down perfect with my front axels and nuts. As the nut bottoms out and tightens, the wheels have no play and spin perfectly. And I have to admit, I have been turning better lap times with the Jacos. Currantly they are cut down to around 50mm (1.98") Hope I can make it one more race day without having to buying new ones.
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Green Machine! is offline   Reply With Quote
Old 12-13-2012, 02:28 PM   #245
AdrianM's Avatar
We have been down this road before. Just about any veteran racer can get a set of donuts in any compound, get some purple craft store foam and make a set of BSR purple stripe tires. White rims are just as secure an identifier of the tires being Lilac Spec tires as a purple stripe.
This is a non issue as the idiots that would bother doing such a thing wouldn't benefit from it anyways.
Adrian Martinez
Old 12-13-2012, 02:31 PM   #246
AdrianM's Avatar
BSR fixed this a few weeks ago. They updated their mold and the latest tires fit most hubs great. There are a lot of the original wheels out there that need to be used up but very soon you will start seeing snug fitting BSR wheels.
Adrian Martinez
Old 12-13-2012, 02:36 PM   #247
AdrianM's Avatar
A lot of people cut their Jaco's to the same size as their BSR's. You can't do that. The Jaco rim is smaller in diameter. Just your Jaco's .050" smaller than your BSR's and they will be interchangeable.
Both BSR and Jaco make great products. You just have to understand the differences. BTW, I run BSR most of the time.
Adrian Martinez
Old 12-13-2012, 05:36 PM   #248
Well since were going down this road again. There is another company called GQ. Excellent tires! Presently they just have a Liliac dot and a L on the rims. Soon they will have the famous purple stripe(That I could do myself). You can contact [email protected] -try a set they work great indoors and outdoors.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 12-14-2012, 06:33 AM   #249
Just remember, if you switch from CRC/BSR to Jaco or vice versa, you will need to reshim the car as the offsets are different for each rim. When going from CRC/BSR to Jaco you will need to add shims to get the width back.
Not sure about GQ....
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 12-14-2012, 09:20 AM   #250
I didn't realize the tires were such a controversy. I was just liking the smaller wheel design. My car setting's are almost there and I can't imagine how anything (softer?) than the spec tires can improve on traction. These cars seem to be glued to the track as it is. Hard to imagine a "cheater" tire can make them hook up better, but hey, I'm still new with experience with only one track. And as far as my lap times getting better with Jaco's that may be a misleading statement. I started my first month driving WGT with BSR's and my driving has improved slightly with practice now that I'm trying Jaco's. Doubt the tires really have anything to do with my improved times and driving.
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Old 12-14-2012, 11:00 AM   #251
While this is true, the perception of the purple stripe offering a better solution for tech is still there in the minds of many racers. Perception is a far more powerful agent than reality. In the interest of "perceived fairness" many find the stripe to be a more valuable identifier.
Personally, I'm never that concerned at major events. Most require that tires be purchased at the event, which are all supplied by the same vendor, from the same batch of tires.
Old 12-14-2012, 11:05 AM   #252
Potoczak's Avatar
Trader Rating: 112 (100%+)
Hey guys whats a popular speedo for this class, we run 1s at our local track. thanks
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 12-14-2012, 11:09 AM   #253
The Hobbywing 1s 120a is a great choice.
Old 12-14-2012, 11:14 AM   #254
CFR
CFR's Avatar
New kid on the block
+ YouTube Video
CFR is offline   Reply With Quote
Old 12-14-2012, 11:28 AM   #255
AdrianM's Avatar
+1 Awesome speedo, great price and great support.
Adrian Martinez
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 06:05 AM
World GT? brettness37 Electric On-Road 12 11-01-2010 09:11 PM
Xray X10 World GT Car PitNamedGordie Electric On-Road 262 04-22-2010 02:18 AM
