Old 10-18-2012, 09:54 PM   #226
Still Bill's Avatar
Originally Posted by Green Machine! View Post
What happed with me just now is that the nut did not fully bottom out. The diff action started to lock up but the gear was still just spinning.
Not sure I fully understand "started to lock up but the gear was still just spinning". Does not seem possible.
Check the instructions again and make sure you are assembling it correctly.
- How is the coned washer installed? Concave side towards the red spacer.
- Red spacer installed correctly with the ridged side placed inward towards the flanged bearing in the right hub? Fairly difficult to see the ridged side; but, it's there.
- Two non-flanged bearings installed...one within the spur gear and the other within the inner side of the right hub?
- Using spur with 1/8" or 3/32" balls?
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 10-18-2012, 10:06 PM   #227
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
I recognize this issue! The belleville washer has bottomed out against the 1/4" axle. This has happened because some other product was introduced. Either 3/32 ball vs 1/8, a different axle from stock, some other non-factory part has been introduced, or one of the famous Slapmaster thrust kits has the wrong spacer.
I am still wallowing over the rather cheesy loss the 'Hawks suffered tonight. I will follow up in the morning to see if this has been resolved.
Bill, we are going to miss you at TZGP, you know you will have another birthday next year so you can skip this one..... no one's keeping track at this point.
Brian
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 10-18-2012, 10:22 PM   #228
If you used the 3/32 diff balls then the axle may be too long where it sticks out of the hub on the nut side...you may need to add a shim between the bearing and the spacer to make up for the difference in length.
Old 10-18-2012, 10:29 PM   #229
Don't make me come over there and... well.. Dec 8-15 I will be toes up at Maui doing.... research.
Team Roche USA
Old 10-18-2012, 10:43 PM   #230
Still Bill's Avatar
Brian
Brian,
I'm keeping track...doing the countdown to retirement.
Too many things happening for me just before and just after the TZGP weekend.
Wish the TZGP would be scheduled towards the end of the carpet season as opposed to the beginning; but, I guess it is like the Daytona 500 or something! Or maybe Mark could just have two of them...LOL
Bill
Old 10-19-2012, 12:01 AM   #231
Maui's just a short 35-45min hop on a plane over to O'ahu Next time you should plan a race weekend on O'ahu!
Old 10-19-2012, 10:29 AM   #232
Green Machine!'s Avatar
Send a message via MSN to Green Machine!
I resorted back to my kimbrough gear and 1/8th balls. I run aS100LT Serpent and I am using the stock axle assembly except for the lighweight diff rings. What was happening was, just sliding everything together, something was bottoming out before I even started the nut. The diff rings wouldn't quite touch the balls and gear. So it didn't even have a chance to tighten properly to begin with. Maybe the bearing recess in the serpent diff hub isn't made deep enough. That's the best way I can describe it. But I rebuilt it using ceramic bearings and silicone nitrade 1/8" balls and the CRC aerodiff spacer collar insted of the cone style spacer serpent provides. Along with the standard spring wasshers. It's working great and very smooth now, so I guess i'll be leaving it alone.
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Green Machine! is offline   Reply With Quote
Old 10-20-2012, 01:31 AM   #233
CNTRFLD's Avatar
Trader Rating: 28 (100%+)
Hi, can anyone please tell me what the differences between Sepents;
#410050 & 410050 Kits? I'm new to WGT class and the only differences I can tell from the details is one is a Link-Tube (LT) and the other is just the Link... I have a X10 Link atm and running 1s not niMh if that makes a difference.
Thanks!
| Team XRAY | ORION | SPEKTRUM | Futaba | HUDY | Upgrade RC | AROARARACING | Protoform | McAllister | MYLAPS |
CNTRFLD is offline   Reply With Quote
Old 10-20-2012, 07:40 AM   #234
LonnyJ1950's Avatar
The S100L has an oil filled shock to control side to side pod movement, The S100LT has 2 damper tubes that you use heavy silicone grease in to do the same job. Most people prefer the tubes.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 10-20-2012, 10:01 AM   #235
Actually I run the s100LT. It has both. The new link tubes as well as the horizontal shock for lateral dampening. It's the "51" part number
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Old 10-20-2012, 06:12 PM   #236
CNTRFLD's Avatar
Thats great to know! Thank You! I really appreciate that!
Old 12-13-2012, 10:30 AM   #237
Just though the thread has been quiet too long. Hope everyone shows up Sunday at TQ. Having two full heats of WGT at round one was awesome! So I was realizing, I like the Jaco tires/wheels better than the BSR's. The wheels are smaller and I can cut the foam down smaller as they wear and get more life out of them to boot. Am I right or what?
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Old 12-13-2012, 11:02 AM   #238
Regional Moderator
CarbonJoe's Avatar
Too bad that at a lot of races, since the Jacos don't have a foam stripe to denote the spec compound, they aren't allowed. Since the durometer of the foam is so inconsistent between batches you can't reply on using a meter. It's too easy to cheat by using something other than the spec compound.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-13-2012, 11:54 AM   #239
I did know about the stripe on BSR's but did not know that fact about the Jacos. Good to know
Mine must be really inconsistant, I can never get past 4th place at my local track! lol
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Old 12-13-2012, 12:24 PM   #240
AdrianM's Avatar
For Jaco Lilac Spec tires the White Rim=The Purple Stripe on BSR Lilac Spec tires, i.e. Only Lilac foam is mounted on Jaco white rims.
I like BSR but I have run Jaco Spec tires. I get the same performance/life with either brand.
Jaco rims are .050" smaller than BSR rims. You have to cut Jaco's .050" smaller to get the same performance.
Example:
BSR's at 2.08" run the same as Jaco's at 2.03". At my track Jaco's will traction roll at 2.08" just like BSR's running at 2.13"
Adrian Martinez
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 06:05 AM
World GT? brettness37 Electric On-Road 12 11-01-2010 09:11 PM
Xray X10 World GT Car PitNamedGordie Electric On-Road 262 04-22-2010 02:18 AM
