Old 09-24-2012, 05:44 PM   #181
Gary NJ's Avatar
Originally Posted by wingracer View Post
I love my CRC but all of them are pretty much the same.
Not all the spec tires have the stripe. I know Jaco and GQ do not. The foam is the same for all of them but wheels can make a difference. Jaco has a pretty soft wheel which is good for grip, GQ has a stiffer wheel which may be better in high bite, I'll find out next weekend.
Same servos as 1/12th. Futaba 9650 or the JR something or other are my favorites.
Thanks Sean. Appreciate the opinions. Maybe they'll let me lay down a few drops of Koford Brown before each corner...
Originally Posted by Still Bill View Post
And seeing that CRC is in Rome, NY, they are virtually in your backyard for parts and setup assistance.
Check out the CRC Gen X-10 LE thread on this website to get the full info.
Bill
That is definately a factor Bill. The Calandra's are great guys!
Originally Posted by BullFrog View Post
I can say I've had 2 brands in the last few years- Corally and the CRC Gen X LE. My teammate has tried the BMI, TOP and now the Speedmerchant.Out of the bunch I'll stick with my CRC. As for front servos-I've been using a JR DS3421 with no problems. Tires most have the purple strip and two don't. I use either Jaco or CRC. But I also use Purple fronts and pink rears (Our Florida series allows any tires). But most use the spec tires.
ESC I use NOVAK (Edge, Havoc Pro SC or Impact). Used them all with great luck and success.Presently I've got the Impact- the size of the Edge and in between the weight of an Edge and Havoc. Whatever you choose have fun.
Thanks - I will definately choose fun
Originally Posted by JACK HAMMER View Post
Gary if your thinking of racing this at 360. Stop by I help you out pal
Phil - It's the only place I was thinking of running it I know how much you enjoyed watching me cream the Neocoli Box this summer, I thought I could entertain you as well this winter I will definately be asking you for advice. By the time I get done you'll be sorry you offered...
Originally Posted by YR4Dude View Post
Cheap is cheap. Don't go any less than HW. If you want to save some bucks, get the HW JustStock ESC and put a 1s booster. You're only problem with that is that you'll have to run it with no lipo cut-off, but if you're careful, you can get away with it. BTW all those cheap ESCs are impossible to program without the optional program box, be sure to get one.
Sound advice - thanks. I really wanted to avoid having to deal with a receiver pack or a booster. I have an older SP Gran Turismo ESC I can use to get started if I decide to run the booster. Local rules are blinky so I don't know whether bothering to have a boosted ESC is something I'll ever use anyway.
Gary - GMK Supply
www.gmksupply.com
Great products. Goofy names.
Gary NJ is offline   Reply With Quote
Old 09-25-2012, 08:27 AM   #182
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Green Machine! View Post
Hey R. what's up? Are you running tc or wgt somewhere too? I'm going to start to frequent TQ and CalRaceway as much as I can again.
WGT chassis - check
Tires - check
Body - check
Esc with booster - check
13.5 motor - check
Radio gear - check
1s lipos - check
Time to go out and play - Working on it.
YR4Dude is offline   Reply With Quote
Old 09-25-2012, 08:38 AM   #183
wingracer's Avatar
Trader Rating: 22 (100%+)
Doesn't work. You need to get some Stick-It Red.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-28-2012, 01:35 PM   #184
Green Machine!'s Avatar
Send a message via MSN to Green Machine!
Finally! Now for some test & tune time. No looking under the hood. LOL
With balancing weights I'm at 980 grams on the WGT. Sound about right?
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Green Machine! is offline   Reply With Quote
Old 09-28-2012, 06:21 PM   #185
LonnyJ1950's Avatar
I believe minimum weight for WGT is 930g.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 09-28-2012, 08:12 PM   #186
Still Bill's Avatar
Attachment 975407
Probably all the paint on that good looking body that makes it 50 grams heavy.
You don't need all that rear wing. Wing should get trimmed per ROAR's WGT wing rules. And then tune around that.
Let's see the car sans body.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 09-30-2012, 06:53 PM   #187
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
Default What do you think we should be changed in world gt?
how about 2s and 17.5 or 21.5?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 10-01-2012, 06:04 AM   #188
Making it more popular would help. The current battery and motor rules are just fine now. People are amazed at how fast and how well these cars handle. I did a demo at a new track and almost everyone wanted to know more.
Going to 2S will obsolete the majority, if not all, of chassis out there now and will thin WGT participation immensely. Adding the expense of a new motor will do the same.
AreCee is offline   Reply With Quote
Old 10-01-2012, 08:28 AM   #189
Still Bill's Avatar
Well said.
Old 10-01-2012, 01:58 PM   #190
Decathalon's Avatar
+1 Very well said. For me part of the attraction to WGT is fact that you can go pretty quick on single cell, with a simple, lightweight car.
CRC GenX10 LE Pro 10 & SE WGT, Kyosho Plazma F1, Atomic VMII,Tamiya M05, 1/12th Scale (CRC Xti, Xi & T-Force, AE L4, Yokomo YRX12, Hara AH12) www.smaracing.org - Star Kebab Akihabara :)
Decathalon is offline   Reply With Quote
Old 10-01-2012, 02:10 PM   #191
AdrianM's Avatar
That would increase weight and tire wear.
Very few that have raced 1s Boosted 13.5 WGT thinks its slow. If you want more speed run a 10.5 or Mod motor. That's all the speed you will ever want.
Adrian Martinez
Old 10-02-2012, 11:02 AM   #192
I got some track time. First time out and about .9 - 1 sec off track record. Got the car re-balanced and weighted to 933 grams with 54mm tires. The Serpent kit came with basically soft to medium springs all around. I'm sure whatever TQ sells should fit the side and front and center spring on the Serpent. What would you recomend? Stiffer? My car actually started to want to traction roll in some corners. the two inner wheels came off the ground a few times. I was turning pretty well. I have currantly 10lb front springs, 5.5lb side springs and 14lb center spring. Thanks guys
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Old 10-02-2012, 11:41 AM   #193
wingman2's Avatar
Hi mate, I would say if you are lifting wheels, then your car is probably too stiff. Try softening it up slightly so you still have good steering but without the wheels lifting and possibly traction rolling.
Cheers!
Sponsored by CML Distribution - http://www.cmldistribution.co.uk
wingman2 is offline   Reply With Quote
Old 10-02-2012, 11:48 AM   #194
wingman2's Avatar
There has been a big debate on running 1c/10.5 with 2c/17.5 at our nationals here in the UK, with a weight penalty placed on the 2c/17.5 cars. It turns out that the 1c cars went better through the corners whilst the 2c cars had more zip down the straight. Caused a fair amount of hassle actually so it would be good just to have one class and then there's no argument!
Cheers.
Old 10-03-2012, 06:17 PM   #195
Still Bill's Avatar
What is your front camber set at?
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 06:05 AM
World GT? brettness37 Electric On-Road 12 11-01-2010 09:11 PM
Xray X10 World GT Car PitNamedGordie Electric On-Road 262 04-22-2010 02:18 AM
