Widening wheel base >
Widening wheel base
Widening wheel base
Old 04-16-2012, 11:50 PM
Default Widening wheel base
Hi all, I have an old Tamiya TL-01 that I'm putting back together. My partners going to learn how to drive and I'm using this to teach her, if she likes it I'll get her something decent.
I bought some Xceed foams for it as the old wheels were stuffed. I got the 26mm for the front and the 30mm for the rear. Fronts fit fine but sit in further then the old Tamiya ones, the rear ones sit in further as well and foul on the lower arms.
The wheel nuts screw in quite a bit as well leaving 1-2mm thread sticking out the end.
I tried putting 2 washers between the wheel and the hex adapter (max I dared to) which was fine for the front but the rear wheels still just and I mean just fouled on the lower arm still.
The problem would be easily fixed if I could find some wider hex adapters, or some way to widen the ones that are on it?
Anyone help?
FST4RD is offline
Old 04-17-2012, 01:25 AM
jayjay283's Avatar
these ?
Tamiya drive hexes in varying widths: 4mm - #53570, 5mm - #53823, 6mm - #53569.
4mm @ towerhobbies, 5mm on ebay, 6mm out till apri @ tower
http://www.ebay.com/sch/i.html?_from...All-Categories
jayjay283 is offline
Old 04-17-2012, 01:30 AM
JamesHealey's Avatar
Just to be pedantic it's widening the track.
The wheelbase is the length.
JamesHealey is offline
Old 04-17-2012, 03:03 AM
The TL-01 is a very narrow car, Tamiya actually make axles to widen it. Axles part number 50808 have longer screw threads, designed to be used with the 12mm long hexes which are spare parts included with the TL01 toe in rear upright, part number 53345. These will move the wheels out 6mm on each side, but if it's too wide you can cut down those longer hexes or swap them for something narrower.
terry.sc is offline
Old 04-17-2012, 01:01 PM
Your right! Was a late night that one!
FST4RD is offline
Old 04-17-2012, 08:57 PM
jayjay283's Avatar
Where are you for that one James Healey... Your ? You're
