P2K2 Pro Installation
This is my first electric. I am installing a P2K2 Pro on my TC3 F.T.
and I have some questions:
The P2k2 has 4 motor tabs, two of them have the brushes solder to them. Do I use the other two tabs to solder the ESC wires or do I have to use the same tabs the brushes are soldered to ?.
Does the positive motor tab has to go in a particular side of te car ?
If you have pictures of the P2K2 Pro installed, I will like to see them. Thanks for your help.
all motors are basically the same~~
doesn't really matter which side you solder the wires onto as long as the positive wire goes to the positive side and negative wire goes to the negative side~
for best results solder your leads to the side w/ the brushes attached. then just make sure your red wire in on the + side of the motor.
