F104 wide track conversion kit set new record at UF1Series on Feb 4 at TQrcracing
#91
I don't know if I can make a shim like you did, but I'll see if there's anything I can find that might fit.
RSector....If you machine the pin hole in about .008mm would that fix the issue?
#93
i ran with my friends conversion kit today. the rear had this slop that these people talk of.i found the car would corner very good but in some corner the car would snap oversteer. i think it was from the axle slop sliding from side to side,when it moves super quick acros it makes pressure on outside wheel like a brake to spin out. fill the slop with spacer and the car was very good over all track. consistant turn everywhere. my friend want his kit back return straight away so i now must buy one myself
#94
I bought the kit too and its great but got the same slop problem......i wish manufacturers would test there products first and fix these issues before releasing the item , instead of leaving it to the end user to fix
#95
RSector, you going to fix the issues and send out replacements?
Anyone have a link to the washer that's needed to make the thing work?
#96
Ya for what you pay for it ,it should have been tested first..... 50 bucks and its got slop......not a good move ....i would definately think twice now before i buy somethimg else from rsector
#98
I think if you are gonna make a product and charge people 50 bucks for it that this company should have a tamiya f104 in there factory and keep test fitting until its perfect then release the product since these measure arent taken why should the end user spend his dollars on a product that wasnt even test fitted before its put on the market .....and if it was test fitted and the company noticed the slop but decided to ship it out anyways will result in bad publicitiy which in turn will result in lower sales hence whats being talked about here ......if the company made sure the product fit perfectly in the first place all that would be said here is praises for such a good product but since a short cut was taken = bad press....come on its simply!
#99
#100
like you stated, "its simple"... what is the tolerance difference of the rsector part and the stock piece? is your rear hub the same sizing as everyone else? lets be honest, all the parts are mass produced and are supposed to be within a couple thousanths, it just doesnt work all the time. shim it and race!
#101
We do testing on all our products before we sell them and we have nothing but positive feed back from this particular product except minor slop which did not come from our hex but from the tolerance of the wheels. Please don't be so harsh on us. Thanks
#102
I notice that the car is much better with the kit than without, thats whats most important. I will be proudly using it this weekend in Texas.
#104
#105
i used two different rear wheel stop before finding a shim to make up the gap. i had the kit stop with the sleeve. then i have a lend of the tamiya clamp stop,still slop.find small 5.5mm .08 shim to use with the tamiya clap,problem fix. the conversion is a very good for the 104 i do not doubt. but it could have been made slightly better with out this slop. it does not sound like it has happened to only one or two but more than that. its a simple fix so hey,no problem really
