265mm wheelbase x 200mm wide?
If had a couple different HPI bodies on a JL10e. One of the HPI Mustangs -- 65 or 66 that is VTA spec and one of the Suburu bodies with no real problems. All 1/10th TC chassis are pretty much the same wheelbase. You can adjust the track width (190mm vs 200mm) with wheel offsets and/or wider/narrower hexes.
I'd think with only a 10mm difference, you could easily cut the wheel openings to accomodate this.
