LiPo Battery True C Rate !!
#31
Company Representative
The biggest battery factory for lipos and lifep04's is based in china and uses material imported from japan it is also Government funded with an unlimited budget and some of the best chemical engineers in Asia.
The highest they have reached is 6000mah for a 7.4v 5200mah for a 14.8v and 5500 for a 3.7v and that is from november of last year and a cont racting of 60c
No more comments id let you figure out the rest about others who claim these rediculous ratings we see today .
Have you personally tested a 3000mAh cell at 180amps ? If the info comes from the factory you should do your own tests as I got fooled by the factories claims. I think they understand that very few people have the equipment to test at these high rates so they will claim what they feel will sell more packs.
#32
I totally agree with you.
Still would it not be useful for the end user to also know the C rating of the assembled pack?
While the C rating of the cells speak lots of the battery's capabilities the rest of the battery should be up to par with proper connectors, wires etc.
#33
The meter we use can give the IR of the pack or the cells in the pack. We will rate the C rate on our own equipment pictured in this thread. C rate will be based on the cells used in the pack. Once we know the IR range of a given cell we can make sure every pack we sell will be withing the IR range. This is way better than just selling packs based on a factories rating and shipping them out as we get them.
The problem with doing C rate for the entire pack is the connector and wires can't handle enough amps without getting to hot.
I personally believe this can be a game changer as the customer will know exactly what he's paying for as each pack will come with the IR of each cell marked inside the packaging.
I'm also considering checking the match of the cells for mAh as I have seen this can also be a problem. Everyone claims there packs are matched but once again are they really matched ?
#34
I'm surprised it took this long for someone to look into it.
#35
EDIT: Also in example, the Thunder Power TP820CD charger does, as many other do. Not that new fangled Orion though..
#36
No fires to report of yet. When you try a cell at to high of load it just cuts off right away.
I do believe our packs are well matched as I have tested some but with the new rating system I want to push it to another step and check every pack and most likely include a graph showing each cell within the pack.
I do have some graphs on our FB page.
#37
Danny,
In my testing internal resistance changes depending on the battery temperature. Will you be providing specifications that include the temperature of the battery when tested ?
Thanks,
Jake D.
Thanks,
Jake D.
#38
Yes the complete method that we use will be listed. Unlike the current C rate system that no one lists how they get there results. My goal is to have an accurate system to rate our packs which can be verified by anyone who uses the same meter we do and follows the method we list.
#39
The highest they have reached is 6000mah for a 7.4v 5200mah for a 14.8v and 5500 for a 3.7v and that is from november of last year and a cont racting of 60c.
Nominal voltage for a lipo cell is 3.7V.
3.7V is one cell
7.4V is two cells in series
14.8V is four cells in series
They all can use the same cell, which would have the same capacity. If the highest single cell capacity available is 6000mAH, then putting them in a series would have the same pack capacity (1S, 2S, 4S). There's no distinction between 3.7V, 7.4V, 14.8V.
#40
14.8V is 4 cells in series not 3.
To sell any pack above 5000mAh they need to be built as 2P or higher. Shipping regulations require that no cells be higher than 5000mAh to be considered as a small LiPo and not be classified as class 9 Hazmat shipping.
In the case of a 6000/60C it needs to be 2S2P but you are right where you can use the 3000mAh cells and make a 4S2P to get 14.8V or 3S2P to get 11.1V.
#42
#43
Not to hijack the thread... but yeah, I believe that RC Market has the slowest web "server" in the world. I'm not even joking. They have a lot of stuff but glacial performance !
it probably runs on a 1200 baud modem !
#44
