Old 01-05-2005, 05:12 PM   #1
Default TC3 FT aluminum shock tops w/Lunsford "quick tune" shock mounts?
My understanding of the point of bushings is that the goal is to avoid metal-to-metal contact of same-kind metals. (e.g. in 1/1 scale car engines, brass bushings between steel moving parts is typical.)
So if I use
Lunsford 7311 "quick tune" Titanium Shock Mounts:
Associated 1598 blue aluminum shock tops:
then is it a bad idea to use the
Associated 1780 blue aluminum bushings?:
I could stick with the standard
Associated 6473 plastic bushings:
but I was hoping to use delrin rather than plastic bushings.
The solution I'm thinking of is:
RPM 70181 Delrin Pivot Balls
which have the right I.D. for the Lunsford 7311 but the O.D. of the balls is too large to fit in the shock tops. My plan is to ream out the I.D. on the shock top to fit the O.D. of the RPM balls, allowing just enough slop for free movement.
billwilner is offline   Reply With Quote
Old 01-06-2005, 01:48 AM   #2
Bill....For this low movement area of the car, you can get away with almost anything for a while...... but like you already knew,the aluminum cap against the aluminum bushing will slowly fight each other and wear, in time causing slop that you can't tighten away.........IMO the longest lasting and most frictionless combo is the aluminum cap and the stock black bushings.......all of the delrin bushings iv'e used in this area gave some unwanted slop after a couple runs........ Don't make too much work for yourself on shock caps
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 01-06-2005, 07:49 PM   #3
ovalnator's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to ovalnator
the delrin pivots are for the bottom rod ends of the shocks, not sure if they would work as a shock bushing
ovalnator is offline   Reply With Quote
Shock absorber "pack"? haulin79 Electric Off-Road 5 03-13-2016 03:51 PM
New "BB" diff and shock fluid!! glassdoctor Nitro Off-Road 6 03-31-2008 12:46 PM
WTB: TC3/TC4 Lunsford Quick Tune Shock Mount (only need 2) cpatel529 R/C Items: Wanted to Buy 0 03-29-2008 12:13 AM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 09:04 PM
Team Magic "Shock" 1/8th On Road. Anyone seen one of these....??? cossie Nitro On-Road 4 01-10-2005 07:32 AM
SEO by vBSEO 3.5.0
