Old 01-14-2005, 09:43 AM   #1006
OSherman's Avatar
Default Re: Re: Re: BK's car
Originally posted by Evicerator
I think that this reaction to having a number of fans in your car is somewhat understandable to someone who hasn't seen the difference that keeping your motor just a little bit cooler can do to your run time, power, and motor condition.
Having three fans in his car is not a function of the stuff not working without it. Having three fans in his car is a result of a few things. The first of which is wanting to make sure that he gets the best performance out of his equipment in very high load situations for the full five minutes. The second is the fact that when your car is underweight, you might as well add weight that will actually benefit you somehow, instead of just sticking a lump of lead in a random spot.
Cooler equals more efficient and consistant in the realm of electronics. If you were trying to win a race against the very best in the world wouldn't you want your car to be as efficient and consistant as possible?
I have been waiting for someone to post this...
I woulda but couldn't come up with the rite words...
well spoken Evicerator..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 01-14-2005, 10:35 AM   #1007
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I have been running fans for over two years on my equipment and it has been working wonders. At the end of my run when geared correctly, I was still doing the same lap times as when I had started my run.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 01-14-2005, 10:45 AM   #1008
lee82gx's Avatar
Do you blow air at the motor or the speedo?
My Novak TC2 runs soooo cooool there is never a need to cool it no even when I'm running sub 10T motors.
The GTX is rated to be lower resistance than the TC2 or any other Novak, so why the need to blow it cool? Is it really hot or is it just there to make up some weight?
lee82gx is offline   Reply With Quote
Old 01-14-2005, 11:02 AM   #1009
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
If you read Steve's post, the cooler things are, the better. It's not a matter of it over heaing without it. They were probably a little under weight and figured functional weight that help keep things even cooler would be the best way to make weight.
Jon Kerr is offline   Reply With Quote
Old 01-14-2005, 11:19 AM   #1010
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
Default Re: Re: BK's car
Originally posted by NR
It dont look to good for the novak GTX and the new Cobalt motors when theres 3 fans in the car it gives you second thoughts on the motors. and the speedy well yes i need a fan on mine to which i think is appalling. It will def be the last novak i Buy
i didn't say that i like kinwald's because it's loaded with fans....
i just said that this car is probably the kinwald's car because he usually put fans everywhere on his cars.......
but i don't think using fans is something to worry about the quality of the products.....
i don't use fans to blow my esc, but i do use to keep the motor endbell as cooler as possible.....the motor keeps its performance, no fading, no burnt brushes.......
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 01-14-2005, 11:28 AM   #1011
WVRACER's Avatar
Send a message via AIM to WVRACER
where do you guys get you fans from and what size are thay
a link would be greatly helpful
Rob
WVRACER is offline   Reply With Quote
Old 01-14-2005, 11:38 AM   #1012
Rob Mincey's Avatar
Reedy makes replacement fans for their heatsink/fan combo. $9.99, part number: 448.
You can also find them at computer/electronics supply places. I'm not sure of the voltage on the fans. I've used 5v fans as well as 12v fans in the past. My receiver's BEC puts out 5v, so it's a good match with the 5v fans. The 12v fans don't get enough juice to blow at full power, so...
I paid more than $9.99 for my fans by the time shipping was figured in, so you can make your own decision on that one.
Rob
Rob Mincey is offline   Reply With Quote
Old 01-14-2005, 11:56 AM   #1013
i bought mine from www.digikey.com
35mm fan 5volts.....I installed the fan standup blowing ainr on the whole endbell......
Salvadori Racing
Old 01-14-2005, 12:12 PM   #1014
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
http://www.allelectronics.com/cgi-bi...164&type=store
they also sell some fans, but not sure how small they go...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 01-14-2005, 12:56 PM   #1015
The Evicerator
I wouldn't recommend going smaller than 25mm x 25mm... anything less than that and the CFM just isn't good enough to do anything....
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 01-14-2005, 01:00 PM   #1016
indeed.....
this 35mm fan was used on a xray (installed like Jilles Groskamp and Greg Hodapp do)....
but I think on shaft cars a 40 or 45mm will be nice....
Salvadori Racing
Old 01-14-2005, 02:00 PM   #1017
Default Fans
We mounted a 1" sq, (25mm) fan on the nerf wings of our TC3's, 5 v fans, 1.8 cfm (be sure to ck this because there are some out there that cost less, but only put out about half the air (cfm). Dropped the motor temp about 30 deg, same gearing, just helped the motor brush to live longer, and be as good at the end as it was at the start. Jameco Electronics.
JWATT is offline   Reply With Quote
Old 01-14-2005, 02:07 PM   #1018
FIRE RIDER's Avatar
or you can be cheap like me and use to playing cards some ca glue and a little bit of electrical tape and build an air duct. lol it worked becasue i didnt overheat but my battery dumped to so maybe thats why o whell either way i was geting air blown accrost teh fins.
Owner and original purchaser of LST2#000689. RPM Arms,Sway Bar Kit, TiNi Gears,HD center skid plate, FOC and Gear swap, 420Kingpins, wing kit, body. Stuff still to do/get for 2016 season: Replace engine.
TLR22 SCT2.0 ZTW 6.5 120A SSPro ESC and Motor
Tamiya LunchBox (Project Racebox) More later
FIRE RIDER is offline   Reply With Quote
Old 01-15-2005, 04:59 AM   #1019
WVRACER's Avatar
thanks guys
Rob
Old 01-15-2005, 07:30 AM   #1020
davepull's Avatar
Hey Shane How are the pictures coming????????????????
davepull is offline   Reply With Quote
R/C Tech Live @ the 2005 US Indoor Championships futureal Electric On-Road 750 01-03-2006 09:37 PM
2005 International Indoor Championships LIVE futureal Electric On-Road 63 09-28-2005 10:59 AM
R/C Tech LIVE at the 2005 Reedy Race of Champions @ Tamiya USA speedxl Electric On-Road 1045 07-18-2005 07:12 PM
U.S. Touring Car Championships - Presented By Novak. At Trackside, Jan 5th-9th, 2005 RC Scoring Pro Racing Forum 118 01-04-2005 11:11 PM
R/C Tech Live @ the 2004 Novak US Touring Car Championship futureal Electric On-Road 362 01-23-2004 08:19 AM
