Novak Brushless System >
Old 01-02-2005, 12:05 PM
Secret_weapon's Avatar
Post Novak Brushless System
Hi guyz
I have the NOVAK BRUSHLESS SYSTEM and i have a problem loosing control from the car. It seems to bee that its not from the reciever or any interfierence. I did the standard setup for the ESC but it still goes out of control and i broke the hub twice because of that.I changed the soldering and did the perfect maintanace but it is still going crazy.
Secret_weapon is offline
Old 01-02-2005, 01:33 PM
Post
just sounds like yor reciever is out of range .. you might want to have your radio re calibrated.. or the antenna wire is in a position that is grounding against the chassis some where .. also make sure the connections on the reciever and speed control are not loose ... but if you've been running it for a while then this happends it might be over geared , causing it to over heat and loosing control .. chk thes things out .. good luck ..
mb racer is offline
Old 01-02-2005, 03:30 PM
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
The only thing I ever had make my Novak glitch or have problems was a damaged/loose input harness. They unplug from the ESC, and if you're not careful, they can come a little loose and you wouldn't necessarily see it.
I've also chewed up a couple of them -- THAT will make it go crazy and it doesn't take much fraying to do it.
I love my 4300 motor -- I hate to go racing at places that don't allow them.
Turbo Joe is offline
Old 01-02-2005, 10:28 PM
Post
Thanks guyz
