Old 12-29-2004, 05:11 AM   #1
Rod M's Avatar
Default 1700SCR cells
I recently gave a mate of mine my old TA04, a old radio and ESC, (for Xmas)
he used to race ages ago and he managed to find his old 1700SCR stick packs that have been sitting around for about 5 years, they look like they are still in good condition and should be fine for 540 class,
what delta peak/charge rate should I use to charge them up with? (I cannot find anything on the forum/web)
Rod M is offline   Reply With Quote
Old 12-29-2004, 06:06 AM   #2
kufman's Avatar
I would start low and work your way up. Maybe 4 amps and 10mV/cell delta peak or somthing like that. If they haven't been used for a while, they will probably false peak the first few times. Keep track of their temp while charging. If they go above 120'ish then they are either getting over charged or the current is too high. The base settings on the novak millenium pro for Ni-cd sub-c cells calls for 4.5A with 14mV/cell cutoff.
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Old 12-29-2004, 06:43 PM   #3
gege's Avatar
Send a message via MSN to gege
I recently charged my old 1700scr (red color) and 1700SCR-SP (black color) with my new charger Eagle CDC at 5 amps and 15mv/cell. These packs have been never used since 1998. No false peak and fully charge. Strong Cells !!!
gege is offline   Reply With Quote
Old 12-29-2004, 08:49 PM   #4
nashrcracer's Avatar
R/C Tech Charter Subscriber
and just think I tossed 150 of those a couple years ago
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 12-29-2004, 10:16 PM   #5
Make sure the batteries do not get as hot as your avartar and you'll be fine! lol
JKA is offline   Reply With Quote
Old 12-30-2004, 03:00 AM   #6
I just charged a 10 year old set of Red SCR1700's on my CDC using default peak (10mv) in fuzzy logic mode...
Wanted to see how good they were, ie can I keep them to run my Comm lathe...
2 cycles later and they dump a solid 1850mah in discharge...
Second pack refused to charge, said voltage too low... Probably a reversed cell in the pack..
Ah well 1 out of 2 not bad for the age of them...
Galifrey is offline   Reply With Quote
Old 12-30-2004, 04:04 AM   #7
cr250 is offline   Reply With Quote
Old 12-30-2004, 05:52 AM   #8
vtl1180ny's Avatar
If you're going to try that with old cells, trickle charge them overnight first.... I have a real old pack of matched 1200's and 1400's that still have some decent capicity left in them.... It's hysterical to look at the numbers though....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 12-30-2004, 06:48 AM   #9
Originally posted by cr250
Rod M - Recently I built 3, 6-cell packs of 1700s for my brother. They were purchased from World Class several years ago and never assembled. For their first charge I used my GM Commander set at 4 amps. All 3 packs would not peak and just kept accepting charge. I stopped the charge on each one at 2.200 mah. The strange thing was they never got hot. I ran each pack in a Stampede and they seemed OK. I let them rest for a day and charged them again at 4 amps. The second time they charged and peaked as expected. Since then they have been used many times and they work great.
On a low amp charge, new unformed/unmatched pack can often take a silly first charge, I have seen as much as 4000mah on some 2400's in the past used in my heli flight packs...
It surprises me that they didnt peak at 4a tho, having said that 2200mah isnt an awful lot for a first charge on those cells...
Old 12-30-2004, 10:21 AM   #10
Old 01-02-2005, 12:53 PM   #11
Cole Trickle's Avatar
I have a pack of Sanyo RC-1700, which is 3 year old. They've been charged with 6 amps all the time. They still perform reasonably good (age and price considered), and a individual cell cycle, showed that each cell is quite even. And it have never been a matched pack
Data: (Ccap, Dcap, Peak, Vaverage, IR)
Cell 1: 2393, 1776, 1,676, 1,047, 12
Cell 2: 2387, 1743, 1,630, 1,055, 11
Cell 3: 2441, 1722, 1,582, 1,062, 11
Cell 4: 2441, 1755, 1,581, 1,071, 10
Cell 5: 2218, 1726, 1,675, 1,064, 11
Cell 6: 2556, 1770, 1,582, 1,057, 11
Discharge rate is 20 amps and cut off voltage is 0,8 volt.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
F/S - 4 cells 6 cells IB4200 Batteries for TC or Trans Am Solara R/C Items: For Sale/Trade 5 08-11-2008 08:38 AM
2 packs Power push 3600 intel. cells,4 cells whynot R/C Items: For Sale/Trade 0 05-31-2005 08:01 PM
XRAY T1FK - RC12L3 - Serpent 710 - Surge Batteries (4-cells & 6-cells) and more XrayRacer R/C Items: For Sale/Trade 24 03-31-2005 02:19 PM
1.18+ cells -vs- orion's 1.19= cells dawgmeat Electric On-Road 142 03-31-2005 10:01 AM
SEO by vBSEO 3.5.0
