Old 12-27-2004, 06:10 PM   #16
JDM_DOHC_SiR's Avatar
Trader Rating: 30 (100%+)
Default Re: In Stock, punch matter. But how can we get it.
Originally posted by racerkorer
In Stock, punch matter. But how can we get it.???
Can you help. ???
On a Stock motor there are a few things that can be done to them to get more "PUNCH" or "PICK UP" with the motor.... most of it has to do with more that brush hoods that are aligned ..... .alot of a motors "PICK UP" can be made through a little brush hood black magic
Ȼ4.5 Centro+α ◊ ȻT4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
DȻ4-LE ◊ 12R5.2+RDS
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 12-27-2004, 06:53 PM   #17
nothing beats new batteries and motors for the main . taking care of your batt's and keeping your motors tuned will have a greater effect .. also gearing is the key to punch and running fast ...
Mark Barden .
mb racer is offline   Reply With Quote
Old 12-27-2004, 06:59 PM   #18
ChadCapece's Avatar
Default Re: huh
Originally posted by imjonah
What is "punch stock mode" How would you program this on an ESC ?
If you have high quality esc, you will have different settings. The Novak GT7 has setting for 4-cell, oval, smooth mod, punch mod, smooth stock, punch stock, and custom profile.
For more punch, your best bet would be punch stock. This will use the most battery and motor, and give you harder acceleration. If you choose this, along w/ good motors and well maintained batteries, you should be fine.
ChadCapece is offline   Reply With Quote
Old 12-27-2004, 07:14 PM   #19
Charlie O's Avatar
What is punch?! acceleration from one corner to another, every car is different, every battery, motor, transmitter, ESC, and track you run on, it all comes down to how you gear that specific car for that certain condition.
Charlie O is offline   Reply With Quote
Does it matter? Shaunnyg723 Rookie Zone 2 05-22-2008 11:28 AM
.01 volt how much does it matter? YmeBP Electric On-Road 7 11-24-2007 09:34 PM
Does chassis matter so much ? nikkor Nitro On-Road 2 09-22-2005 05:31 AM
does fuel really matter? Tmachine Onroad Nitro Engine Zone 1 02-10-2005 02:54 PM
Does the wing matter? Etahn Electric Off-Road 14 12-28-2002 11:07 AM
SEO by vBSEO 3.5.0
