Charger comparison >
Charger comparison
Charger comparison
Old 12-26-2004, 12:46 PM
Trader Rating: 70 (100%+)
Default Charger comparison
What makes the competition electronics bad ass charger better than say an integy 16x7? Say you set them at the same charge rates and everything what makes it better and why is it so much more expensive?
PROMODVETTE is offline
Old 12-26-2004, 01:01 PM
picco007's Avatar
Trader Rating: 99 (100%+)
I have a turbo 35 gfx and from experience it's a great charger. The gfx can discharge up to 35 amps......whether you need that high of a discharge rate is entirely up to you. It has a motor run in feature that is nice. It has 10 memories for different charge profiles which is nice too. The gfx has a charge and discharge curves that can be looked at. There are other features that I didn't touch on. But other than CE is the industry standard for matchers also stands for something.
Integy has great products too. The 16 x 7 is a great charger. Don't know if it has a motor run in feature though. I know it discharges at 20 amps and charges up to 7 amps.
The difference in price is huge, but I don't think you can go wrong with either. If you don't have a charger look into others and do some comparisons........ It will make you more aware of the differences of each charger.
Hope this helps......
picco007 is offline
