T.O.P. PHOTON EX
#1472
The numbers in the chart refer to how wide they are, to adjust toe and arm sweep.
To adjust the roll center use the shim kit under the mounts, like with the stock mounts.
#1474
#1477
We have a few of the Team Tamale 7075 blocks left. They are expensive but nearly indestructible
[email protected]
650-583-8898
#1478
Any one running the older Photon is USGT ?? I need a good 21.5 setup for a smooth outdoor track low to med grip sunny weather
thanks!
thanks!
#1481
Anybody here using the uPro suspension mounts for the Photon ex? I bought a set from Rc Market and took the car to the track for testing ....I can't get the car to turn tight in the corners I have a tremendous amount of push. I tried about every type of settings springs,oils,camber links amound other things and no luck. Any suggestions?
#1484
