T.O.P. PHOTON EX
#1441
yes you will need the yok blades , the white blades last longer than the black ones but the will wear the out drives quicker than the black ones, so i comes down to what you want to replace more often, also depends on what class you run in, more power quicker wear
#1442
Professor,
Looks like I'll stick to the black ones then. Blades are cheaper than out drives lol! I run 13.5 boosted and 17.5 zero timing. And yes the wear rate is significantly higher on the 13.5. I've tried TOP's hardened grey out drives as well buy they too aren't as durable as I'd like. With AOC around the corner I've been running the EX a lot and the wear is shocking. Everything else on the EX seems to last it's only the out drives that are a constant gripe.
#1443
i have been using yok diffs in all the ex's i have from day one & had no leaks from any of them
Thank you
#1444
I just got an T O P Evolution. I am trying to find a manual so I can mount servo and elect. I do have a T O P photon but I know nothing about the Evo. Can any one help with a web site or info? Thanks
#1446
I have gone to A Main and order the diff for both my cars. But I didn't see the black blades. I saw the white ones ware you get four of the white ones. Am I missing them. Is it me or the black blades from the TOP will not work on the Yok? Are you only running the Yok diff oil you get with the diff?
Thank you
Thank you
#1447
Just a bear chassis to which you could add Tamiya and TOP drive train and suspension.
Not sure if CEFX is still around.
Maybe google an Evolution manual?
#1449
No they come with the white ones. I love my original TOP. I'm sure it will take it sometime to wear the out-drive. One of the guys that I know actually told me also about the yok diff. He didn't go into specifics, this guy has also been racing for quite sometime. He runs X-ray (sorry to high of a price tag). I have never understood the mixing of parts on a car, and have always tried to purchase the manufactures parts. But after looking at both diffs I'm not so sure. One has plastic gears the other steel gears. I'm thinking that the steel gears when oil flows between them, that could create a pressure area, forcing the plastic to stretch, that could be the reason for the diff to leak. The nylon gears on the other hand will give a little. My question would be, do they crack or melt after a period of running? But then like anything else you should be servicing it. That's why I asked if anyone else had run thicker oil in it. Or tried to run the yok diff in front. I have another friend that has been racing on road cars for along time. Mainly nitro, that's ware I began, with the track gone. Had to switch it up. Sorry getting away from what I want to say. He runs a Capricorn car, I don't think it's that great of a car I had own a Capricorn LABC-801, I believe that the Serpent is a much better car. Any ways, his 1/10 scale Capricorn came with gear diffs the second time out with the car he had melted the rear diff on it.
#1451
http://www.apexhobbies.com/Shock-Tef...pcs_p_116.html
#1452
Any news on updated EX? T.O.P. `s website is very quiet......
#1454
My kit comes with v2 steering block and v2 rear c-hub. Do i need castercblock 4 v2 to use the new double join shaft?
#1455
The v2 castor block has a larger opening for the TOP universal. You may be able to take a Dremel to the old ones and make them work. But that will weaken them. I use the V2 castor blocks.
