Like Tree1Likes
Old 02-12-2014, 07:37 AM   #1366
heretic's Avatar
BTW I stand corrected and the WD40 for 48 hours did swell them up a little. I have yet to run the car to be sure, but this should get me going until I receive the new O-rings.
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 02-12-2014, 09:14 AM   #1367
Trader Rating: 17 (100%+)
Originally Posted by heretic View Post
It's arguably a perfectible diff, but for the special application I'm using it in, its lightweight makes it perfect. It just took forever to break it in. I'm using it with some 15.000 CST fluid to get a feeling similar to a regular 4-satellite diff with 2000-ish oil.
Anyway I've found o-rings that are the right dimensions and which look like they could be an improvement ( they're of the orange-red variety). I've also ordered rubber sealed bearings to help with leakage. Overall cost is 7$ including shipping.
Gotcha well good luck.
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 02-21-2014, 10:06 AM   #1368
wuzi's Avatar
For sale,i always rebuild the car for training and race.a lot of new parts and the car is full with hop ups and ceramic bearings,the 3 gear diffs are new.....i race only stock 13.5
facebook.com/rene.kölbel
T.O.P. PHOTON EX-2014-02-11-10.51.48.jpg   T.O.P. PHOTON EX-2014-02-11-10.52.12.jpg   T.O.P. PHOTON EX-2014-02-11-10.52.43.jpg   T.O.P. PHOTON EX-2014-02-11-10.53.14.jpg   T.O.P. PHOTON EX-2014-02-11-11.12.31.jpg
wuzi is offline   Reply With Quote
Old 02-21-2014, 10:10 AM   #1369
wuzi's Avatar
pics
T.O.P. PHOTON EX-2014-02-11-11.13.09.jpg   T.O.P. PHOTON EX-2014-02-11-11.13.30.jpg   T.O.P. PHOTON EX-2014-02-11-11.13.41.jpg   T.O.P. PHOTON EX-2014-02-11-11.13.59.jpg   T.O.P. PHOTON EX-2014-02-11-11.14.11.jpg
Old 02-21-2014, 10:13 AM   #1370
wuzi's Avatar
pics2
T.O.P. PHOTON EX-2014-02-11-11.17.19.jpg   T.O.P. PHOTON EX-2014-02-11-11.14.55.jpg   T.O.P. PHOTON EX-2014-02-11-11.14.40.jpg   T.O.P. PHOTON EX-2014-02-11-11.14.25.jpg
Old 02-21-2014, 01:35 PM   #1371
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
I was able to race my ex last weekend for the first time, this was my 1st time running tc as well and I was able to take the win. Car was great with the setup that was on it.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 02-27-2014, 09:20 AM   #1372
heretic's Avatar
Hi guys;
Just to be sure, the L/R bulkheads are spaced the same on the old Photon and the EX ? Also, are the 4 mounting points of the shock towers spaced the same ? Meaning, I could use an EX shock tower on my old Photon ?
Thanks a lot !
Old 03-25-2014, 10:40 PM   #1373
zephuros's Avatar
Hi guys,
been using the EX for a few months now and it's just awesome! One problem i have tho - i find that the steering rack has a bit of slop in it. I reckon the bearings are not perfectly suited in the crank, and as a result tthere is some slop in them. Generally not a big issue, but i have notice that the car is a tad twitchy when braking into corners... Not sure if it is at all to do with this slop, butif so, what's the best way to cure it? PS, i've tried shimming as well but with limited results. I feel that the whole crank has just too much play in it.
Any ideas?
awww bollox....
zephuros is offline   Reply With Quote
Old 03-26-2014, 12:07 AM   #1374
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Originally Posted by zephuros View Post
Hi guys,
Any ideas?
I've been using the steering rack from the S4, no slop at all using this. Look around and see if you can get a hold of it.
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 03-26-2014, 12:23 AM   #1375
*SBH*'s Avatar
Hi guys,
Any ideas?
Hi there
If the bearings are not glued into the rack, You can do that with CA (Be carefull with bearings and fingers). Besides that, all You need are some 0.1 0.2 0.3 spacers in different sizes, and ˝ hour available, it will be perfect after that
Good luck
*SBH* is offline   Reply With Quote
Old 03-26-2014, 12:26 AM   #1376
*SBH*'s Avatar
Danish SuperStock Champion 2013/2014 - T.O.P. Photon EX
Great car! It's been an awesome season.
https://www.facebook.com/photo.php?f...type=1&theater
http://top-racing.jp/Eng+JP/Index/ne...pionships.html
Old 03-26-2014, 12:38 AM   #1377
heretic's Avatar
Hi guys;
Thanks a lot !
Anyone can help me ?
Old 03-26-2014, 05:11 AM   #1378
*SBH*'s Avatar
That should work
Old 03-26-2014, 06:23 AM   #1379
heretic's Avatar
Originally Posted by *SBH* View Post
That should work
Actually, "that should work" is where I'm at right now...
At 20$ for one tower, what I'm looking for is a " That will (or won't) work ".
I'm sure someone on here has tried/ could try to put one "old" tower on top of a "new" one and see if the mounting holes match. I can live with a slight change in shock position, but obviously not with incompatible mounting holes.
Thanks for your answer anyway !
Old 03-29-2014, 03:24 AM   #1380
madmiki's Avatar
Trader Rating: 14 (100%+)
holes are the same
MIL ROGIC
http://www.topracing.net.au
HOBBYWING
FUTABA
madmiki is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 08:03 PM
