Old 01-20-2014, 05:54 AM   #1351
A new blade measures 3.84 wide. OD across pin mount is 9.97. ID is 5.73. Associated blades are smaller and XRay are bigger.
OldLosiRacer is offline   Reply With Quote
Old 01-24-2014, 04:01 PM   #1352
iVTEC4LIFE's Avatar
Okay so I was nitpicking over my EX today. 30 and ice outside. I had nothing better to do.
I found out that it has double joined axles up front. They wiggle A LOT. Is that normal? Why are DJS' preferred?
AE RC10B3/RC10B3FT/RC10B4 Team Car
Tamiya TL01 Custom Mustang
LOSI 8IGHT-T 2.5: Turbo 454 Racer
LOSI 8IGHT 2.0 EU: Project 3.0 EU Hybrid
iVTEC4LIFE is offline   Reply With Quote
Old 01-24-2014, 06:17 PM   #1353
They are a lot smoother under power in turning situations. A lot of guys have adapted other brands to the EX. Google PO-SDT035 as these are the TOP ones that came out as an optional part last year. They are good units.
Old 01-24-2014, 06:38 PM   #1354
iVTEC4LIFE's Avatar
I believe these are the TOP units. The steel shafts are printed just like the pics I'm googling. Thanks.
Old 01-24-2014, 09:17 PM   #1355
Professor's Avatar
they will also give you more steering, (which for me i liked) so depending on how much steering you like or dont you may have to change your setup slightly
well worth the money imo
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 01-25-2014, 07:25 AM   #1356
The only thing I don't like about the TOP CVD is the inner bearing is a 5X10X3 and not real common so its a little more expensive. But a nice thing is They work real good when you want to swap between a spool and a diff depending on the track. Using a Yokomo diff with TOP outdrives all you have to change when swapping is the plastic blades. So you can have a spool and a 2.5mil diff that can be swapped in less than 5 min.
Old 01-29-2014, 11:18 AM   #1357
iVTEC4LIFE's Avatar
So I finally got to drive it today. 38 out. No overheating issues to worry about. (That and my 7.7 FD)
I'm completely new to brushless so first I was impressed with the quietness of the system and the smoothness. Next I was amazed at the increase in run time. 20mins of driving and when I came in to discharge the rest of the battery and waited another 3min for the lights to go out!!
The next thing I was shocked by was the handling of the car. The last TC I had had a ball diff up front. This spool makes the car turn HARD under power. Very cool.
Lastly, the rear wing fell off my HPI BMW M3 GTR during my run and I was astonished how much the handling changed. It's what caused me to stop driving.
Overall tho, I'm very happy with the car. It's quiet. Butter smooth and responsive.
Old 02-02-2014, 11:49 AM   #1358
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
Is there anywhere who has a chassis for this car in stock? Or any aftermarket chassis?
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 02-02-2014, 02:50 PM   #1359
Try OD at:
324 Juanita Ave.
Millbrae, CA 94030
Phone: (650) 583-8898
Fax: (650) 583-8832
Email: topracingusa@yahoo.com
Paypal ID: topracingusa@yahoo.com
Old 02-02-2014, 07:13 PM   #1360
Try OD at:
324 Juanita Ave.
Millbrae, CA 94030
Fax: (650) 583-8832
I checked out their website and did not see one listed on the sight.
Rob Jensen
Old 02-02-2014, 08:31 PM   #1361
vabroom's Avatar
Their first site got hacked. They are racers and do not have much experience on websites. Just email them about what you want and OD will get back to within a day. They are very quick processing orders.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 02-03-2014, 07:43 AM   #1362
Cool I did just that.
Rob Jensen
Old 02-12-2014, 02:30 AM   #1363
heretic's Avatar
Hi guys,
Anyone know of a replacement for the 5mm x 8mm x 1.5mm o-rings for the outdrives of the Micropro diff ? Mines are leaking no matter what I do. I've tried soaking them in WD-40 for a few nights but that didin't help; they barely get softer and didn't swell by any perceptible amount.
I build my diff with green slime on the o-rings, and properly shimmed. It's not my building technique, just crappy o-rings. I found some 6899 HPI o-rings online but from the look of it they're just the same kind of solid hard rubber instead of a real silicone hollow o-ring. Not sure though. Traxxas Jato diff O-rings *look* like they could be a fit, but I couldn't find their measurements anywhere.
Next option is spraying motor brake cleaner on them to make them swell but I'm reluctant to try, for obvious reasons. Gluing them inside the case with CA is of course not an option, let's be serious.
Thanks in advance for your help !
PS: I know this is not the original photon thread, just thought there would be many more people in here.
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 02-12-2014, 06:53 AM   #1364
Trader Rating: 17 (100%+)
If that's the diff I'm thinking of, it needs to find its way to the garbage can, and spend $40 and get another full sized diff.
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 02-12-2014, 07:29 AM   #1365
heretic's Avatar
It's arguably a perfectible diff, but for the special application I'm using it in, its lightweight makes it perfect. It just took forever to break it in. I'm using it with some 15.000 CST fluid to get a feeling similar to a regular 4-satellite diff with 2000-ish oil.
Anyway I've found o-rings that are the right dimensions and which look like they could be an improvement ( they're of the orange-red variety). I've also ordered rubber sealed bearings to help with leakage. Overall cost is 7$ including shipping.
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 08:03 PM
