Old 01-13-2014, 06:04 AM   #1336
iVTEC4LIFE's Avatar
Thanks guys. And I'll be sure to use some "astroglide" on the threads. LOL
AE RC10B3/RC10B3FT/RC10B4 Team Car
Tamiya TL01 Custom Mustang
LOSI 8IGHT-T 2.5: Turbo 454 Racer
LOSI 8IGHT 2.0 EU: Project 3.0 EU Hybrid
iVTEC4LIFE is offline   Reply With Quote
Old 01-13-2014, 02:57 PM   #1337
iVTEC4LIFE's Avatar
Originally Posted by meddman View Post
Where you guys buying parts? I have a TOP sabre mini
I have the EX and so far I'm only buying from Amain. But they don't carry Sabre parts....
There's https://apexhobbies.3dcartstores.com/ BUT I'm not sure about them yet as they don't seem to have the same security as Amain.
After that I defer to the experts here.
Old 01-13-2014, 04:05 PM   #1338
Trader Rating: 17 (100%+)
Well since the Sabre isn't for sale in the US....... Probably going to be hard to find parts for. You might have to get a hold of TOP USA directly, or shoot me PM with what your looking for I can get a hold of them for you.
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 01-15-2014, 12:55 PM   #1339
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Attached is my S4, pretty muck complete now just need the sensor wire.
Overall build was better that the EX IMO.
Some nice touches are:
New steering rack, gets rid of the slop that the EX rack had.
Center pulley assembly is nice and simple
Shocks are actually shorter than the EX as I mentioned before.
Main issue so far is due to the motor mount this will limit gearing options for 21.5/13.5 blinky.
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIGE BEARINGS*
A Ilievski is offline   Reply With Quote
Old 01-15-2014, 09:22 PM   #1340
iVTEC4LIFE's Avatar
Looks smaller than the EX. I like how they eliminated a lot of aluminum. Especially in the rear. I also like the integrated sway bar mounting system. And the hinge pins...
Still setting up my EX. I have found some extra movement fore/aft in the arms that I'd like to limit and of course I need those sway bars but over all I'm very impressed at the leaps and bounds TC's have come since I last owned one. RS4 Pro2. I can't wait to run it this weekend!!!
Old 01-15-2014, 11:54 PM   #1341
Why not start a new thread for the S4? Will be easier for everyone
faifaisalfal is offline   Reply With Quote
Old 01-16-2014, 01:28 PM   #1342
Im sure someone could. I don't think it has mostly because as of now its not released in the US.
T.O.P Racing USA
Old 01-16-2014, 03:12 PM   #1343
Professor's Avatar
are you guy's getting this model in the states ?????
VBC RACING-R1 WURKS AUS--HOBBYWING--SILVERBACK--MAD GRAPHICS--BLITZ
Professor is offline   Reply With Quote
Old 01-19-2014, 10:05 AM   #1344
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
So I have the aluminum gear diff out drives on my car but can someone tell me why they are bored out so much larger than the ball on drive shaft bones its a ridiculous amount of play and I have 2 sets that are the same and the slots for the blades are even over sized so my rear drive shafts flop around during rotation making for an inefficient noisy setup.
jeff jenkins is offline   Reply With Quote
Old 01-19-2014, 11:46 AM   #1345
The aluminum out drives on the gear diff are stock and no one I know of has a big issue with them. They will wear out before the plastic blades but you can see the wear. I just checked out all three of my cars and see no issue. Do you have pix?
OldLosiRacer is offline   Reply With Quote
Old 01-19-2014, 01:23 PM   #1346
JayBee's Avatar
Trader Rating: 31 (100%+)
Thanks Jeff for giving me some laps on that new Photon. The car felt awesome.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-19-2014, 02:32 PM   #1347
well m not sure how I can get a pic to really show it but I ordered up the PO-DT0018H outdrives and I have the aluminum driveshafts in the rear. I have used both the tc6 and the photon blades and there is a lot of slop between the blade and the outdrive and on top of that the ball of the driveshaft is also dealing with the same issue. im not an idiot and I am a machinist so I know a thing or two about fitment and tolerances so I guess I can just say this is typical china quality tolerance.
Old 01-19-2014, 02:35 PM   #1348
no problem JayBee , the car is really nice to drive right now. I feel it has good corner-speed but still trying things to see if more improvements can be made.
Old 01-19-2014, 09:21 PM   #1349
I would say I have about .3mm slop between the blade and the ball with new parts. The plastic blades are slip fit with no slop with new parts. But the alloy outdrives do wear on the torque sides and get loose. This can inhibit suspension travel under power.
On another note. Try measuring rear toe on each side with the car assembled. Many cars have a chassis issue requiring more shims on the LR to get the same toe on both sides. This can cause some real hidden handling woes. But not all cars have this. Must use a good set-up station to find like a HUDY.
I do like the car despite some quality issues. it can be made to work well.
Good luck.
Old 01-19-2014, 09:40 PM   #1350
Good luck.
yea something is wrong with mine then. I have a lot more play than what you stated and I forgot to mention I am using new parts here except for the driveshafts but they are not in bad shape. this car works amazingly right now. I have had 2 solid weekends in a row with the car to work on setup and so far everyone that has driven my car feels the same. I really enjoy this car at the moment and plan to stick with the car
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 08:03 PM
