Like Tree1Likes
Old 07-31-2013, 05:31 PM   #1231
Professor's Avatar
Originally Posted by Coxy View Post
Yes I have tried it but im yet to decide on my views about it. Give me another night with it.
Coxy.
ok will talk on friday nite
graham
VBC RACING AUS--HOBBYWING--RC MAKER--
MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 08-03-2013, 05:58 AM   #1232
ghostman24's Avatar
Trader Rating: 25 (100%+)
Default new springs
Does anyone know what the lb/in would be on the new springs? They are 274gf/mm, 260gf/mm, and 248gf/mm. I have not found the lb/in anywhere. Or is there a conversion? Thanks.
ghostman24 is offline   Reply With Quote
Old 08-04-2013, 03:36 PM   #1233
odpurple's Avatar
From T.O.P.'s part listing:
274gf/mm=15.3lb/in
260gf/mm=14.6lb/in
248gf/mm=13.9lb/in
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 08-05-2013, 01:08 PM   #1234
ghostman24's Avatar
274gf/mm=15.3lb/in
260gf/mm=14.6lb/in
248gf/mm=13.9lb/in
Thanks. OD
Old 08-09-2013, 09:00 AM   #1235
Default EX Question
Finally received my EX and here are some question for you guys.
1. The rear hub now has 3 holes in it, and the manual is not updated! So what now? I ran the middle one for now, car is planted!
2. The left and right A- arms as per manual give you different toe-in angles, why is this? I have shimmed it to be the same and have found this on 2 cars already, Help?
3. Anybody had issues fitting a STD Savox servo? Mine hits the steering crank arm post. Once again more shimming required, but sorted.
Thanks in advance.
PS: Ran it last Sunday and I am quite happy with it considering I used mainly std rubber setup, A pity it was against a bunch of TT01`s so no competition really
benTC5 is offline   Reply With Quote
Old 08-09-2013, 12:39 PM   #1236
Trader Rating: 17 (100%+)
Thanks in advance.
1. I'm running the center hole and seems to work fine.
2. Not to sure what you mean, but I know you have to be careful installing the arms. On my first car I didnt realized the shock mounting positions were different side to side...
3. I had the same issue with my Savox. Just trimmed down the servo saver. not all servos have that problem... Don't know why.
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 08-13-2013, 11:48 PM   #1237
*SBH*'s Avatar
TQ and Winner of the latest round of the Danish National Championships. I will share my setup here soon. The car was awesome, precise and easy to drive.
We have a great car
Søren Boy Holst
*SBH* is offline   Reply With Quote
Old 08-14-2013, 03:29 AM   #1238
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Well done Soren!!
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is offline   Reply With Quote
Old 08-14-2013, 09:53 AM   #1239
Awesome looking forward to seeing the set up!
T.O.P Racing USA
Old 08-21-2013, 11:20 PM   #1240
*SBH*'s Avatar
Hi guys
Sorry for the delay, but here is the link to the setup
http://www.petitrc.com/reglages/top/...t_GRC20130811/
This setup secured the Danish National Championships outdoor
http://www.redrc.net/2013/08/soren-b...ps/#more-70371
Good luck guys
Søren Boy Holst
Old 08-27-2013, 10:09 AM   #1241
Default New Top???
I found this picture on TOPS facebook page...
New car in the works????
T.O.P Racing USA
Old 08-28-2013, 12:35 AM   #1242
*SBH*'s Avatar
Testing of new parts for future knowledge
Like all the big companies do
Old 08-28-2013, 01:39 AM   #1243
Nicely blurred out yok rear suspension also
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 08-28-2013, 02:50 AM   #1244
Originally Posted by big paul View Post
Do the guys who got the first floating servo mount get a refund as it was crap and not fit for purpose. As you had to tape the servo to stop the servo moving.Will the new one work? as it seems to me TOP cannot research there products. As the case with the screws/ wrong sized bearings eg on the steering/ the serrated wheel nuts that are a joke/ the nubs on the shock shaft that need removing and down't get me started on the gear diff. The real shame about this is the ex would be a great car if it was not built on the cheep.They charge xray prises but tern out poor quality.So I as well will be getting out from TOP.
+1 ..my chassis has been sitting in a box for over a year now. one problem after another after another. had to use the shocks off of my old photon chassis just to keep from scraping my chassis. finally found splintered carbon graphite
o the bottom side of upper brace. right next to where many of the holes are drilled. This pos has driven me right out of tc and most likely will not go back. I do not feel it would be right to sell this pos to anyone else. So in the mean time i went to 1/12th scale in winter and run open 4x4 slash in summer in the on road class. Both of these vehicle absolutely shame anything i ever had from top as far as quality.
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 08-28-2013, 07:12 AM   #1245
[QUOTE=bpalmer;12491548]+1 ..my chassis has been sitting in a box for over a year now. one problem after another after another. had to use the shocks off of my old photon chassis just to keep from scraping my chassis. finally found splintered carbon graphite
o the bottom side of upper brace. right next to where many of the holes are drilled. This pos has driven me right out of tc and most likely will not go back. I do not feel it would be right to sell this pos to anyone else. So in the mean time i went to 1/12th scale in winter and run open 4x4 slash in summer in the on road class. Both of these vehicle absolutely shame anything i ever had from top as far as quality.[/QUOTE
Your issue stands from one thing. Bad shock collars.. DID you know they replaced all of those less than a month out... and it was FREE......... That was really the only issue with the car. The rest sounds like set up issues.....
Sorry for your frustration...all you had to do was 1. post on here your issue and you would have been taken care of or 2. call TOP directly they would have fix it for you FOR FREE!! So please don't come on the forum and just bash when TOP has some of the best customer service out there. Just my .2
T.O.P Racing USA
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 08:03 PM
