Old 03-13-2013, 03:14 PM   #1126
Mitropoulos Jim's Avatar
Yes, I am talking about the hub carriers.
I just use 2x0.4 shim on the rear left side (instead of 1x0.4) and that's all.
Dimitris Mitropoulos
rcdim.blogspot.gr
www.the-painter.gr
Mitropoulos Jim is offline   Reply With Quote
Old 03-13-2013, 03:25 PM   #1127
Sorry, You use them between the external bearing and the pin?
Only on the left side?
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 03-13-2013, 03:56 PM   #1128
madmiki's Avatar
Trader Rating: 14 (100%+)
i think he means inbetween the rear suspension holder and bulkhead.
i run the alloy rear hubs and dont have an issue
MIL ROGIC
http://www.topracing.net.au
HOBBYWING
FUTABA
madmiki is offline   Reply With Quote
Old 03-13-2013, 04:10 PM   #1129
Professor's Avatar
These things donīt happen with Tamiyas or Yokomos...
deleted
VBC RACING-R1 WURKS AUS--HOBBYWING--SILVERBACK--MAD GRAPHICS--BLITZ
Professor is offline   Reply With Quote
Old 03-13-2013, 04:14 PM   #1130
Originally Posted by Professor View Post
didnt realize these 2 brands are perfect
More near to perfection than this one of course...that is what hudy setup table says... not me
Old 03-14-2013, 11:37 AM   #1131
I have used the original Tamiya 5x1,5 mm shims in between the rear ball bearings inside the hub carriers (as 417) and firmly screwed the allens screws inside the suspension rear mounts. Now I have 2.7-2.8 degrees at left side and 3 degress at right side.
Uploaded with ImageShack.us
Old 03-14-2013, 01:14 PM   #1132
Robert_K's Avatar
I never had this problem before. But I also never check the toe with my hudy set. Normally just calculate the toe-in. I'll have a look.
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 03-18-2013, 07:23 AM   #1133
Trader Rating: 17 (100%+)
LF was TQ in 17.5 sedan at nationals this weekend, but fell short in the mains EJ ended up 6th in MOD I believe. It was super close racing! Looking forward to Larrys comments, and (no sway bar set up) to come! I think there was about 60+- entrys in sedan stock
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 03-18-2013, 07:37 AM   #1134
Trader Rating: 19 (100%+)
Congrats to Larry and Hanulec for some excellent runs. Larry's car looked phenomenal.
MDawson is offline   Reply With Quote
Old 03-18-2013, 09:09 AM   #1135
hanulec's Avatar
Trader Rating: 23 (100%+)
Thanks Dawson. Who knows what could of/would of happened without the racing contact out on track. Tight qualifying times often lead to tight starts and the slightest mistakes can cost ya.
EJ finished 4th in 13.5 too.
My Photon EX was really great in qualifying but I think my lack of sleep effect mains day..
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-20-2013, 09:05 AM   #1136
Where any of the photons running the new toe blocks, or the V2 hubs or caster blocks?
If you didnt know there are new 3 hole rear hubs out and new caster blocks 4 and 6 deg for ECS's
T.O.P Racing USA
Old 03-20-2013, 09:18 AM   #1137
L.Fairtrace's Avatar
Send a message via AIM to L.Fairtrace
I was running the new stuff. Rear Hubs, Knuckles, and C Hubs.
Other than that I was running the exact same setup I posted after the Halloween classic. Except I widened the front to 1mm instead of .5 shim for width on the blocks.
Noone was running the new toe block. I also do not plan to run them. I may give them a try on asphalt for the heck of it but I really dislkike that style of toe block and will only use it if it greatly improves the car (which I doubt)
I had everyone covered in 17.5 I just didnt get enough sleep and ran out of talent on mains day. That and getting peeled from behind didnt help my chances. After the first round mistakes I made it took me out of the running about 1/2 through the first lap in the 2nd main and basically the wind out of my sails for the other 5 mains I had to run.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 03-20-2013, 11:08 AM   #1138
Yeah, im sure you had a lot going on!! I almost shed a tear after A1. What hole were you running on the rear hubs?
T.O.P Racing USA
Old 03-20-2013, 11:31 AM   #1139
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Great job to Larry and FJ in TC! Both cars looked excellend on the track. I think they unknowingly ended up with slightly different setups.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 03-20-2013, 11:58 AM   #1140
Jon Williams's Avatar
Jon Williams is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 08:03 PM
