Old 12-31-2012, 05:34 AM   #1081
Mitropoulos Jim's Avatar
Default 2012 ATTIKO CUP GREECE
Last Sunday (23/12/12) it was the last race for 2012, and the organiser of the Greek Attiko Championship decided to make a one-race cup for 2012, the Greek Attiko Cup 2012.
The conditions were a bit tough, with 5 degrees all day. In the morning it was the 1/10 IC ATTIKO CUP that took place so as for the track to have better grip for us, the 1/10 TC. Most of the TC gyus have been at the track from early in the morning to make some practice runs before the race would start, at around 14:00.
TOP Racing team had 3 cars racing, Kostas Kakarikos, Nick Nikolakopoulos ( nnick from www.rcring.eu) and me. Unfortunately, the other members of the team, as well as some other racers couldn't attend the CUP race, due to the cold conditions, and xmas mood...
This is Kostas Kakarikos
This is nnick
And this is me
When the race started, the track was better that the morning's practice runs, but still low/medium grip and very very cold!
At the first qualifying, I cruised to victory and provisional TQ.
But at the second and last qualifying, it was nnick that was faster, and after some bad performance of mine, he managed to TQ the run and the race. I was starting the finals from 2nd which was not so bad.Kostas Kakarikos had some problems during qualifying which dropped him back, but at least he made the top 10.
A1 was a cruise to victory for nnick and a dnf for me, as my transmitter's batt refused to work well(mabe because of it being too old or too cold!).
A2 was ok, as I won, making a pass on nnick and...
A3 was a little bit harder, as the sun wasn't there and after I passed nnick, I couldn't see my car and so could only cruide around the track, to see the fluo yellow-orange xray of Petros Katsikis making an easy pass on me 3 laps before the end of the run.After that I was stuck behind him as I could see his bodyshell better and drive just behind him!!! I tried to make a move on him during the last lap, but it was too dangerous and I gave up, as I had secured the win even finishing second in that run.
So, final results are:
1. Dimitrios Mitropoulos/Top photon EX
2. Dimitrios Konstantopoulos/Xray T4
3. Petros Katsikis / Xray T3
TQ: Nick Nikolakopoulos
Best Lap: Dimitrios Mitropoulos
Unfortunatelly nnick and Kostas had some both some problems and only managed to finish 4th and 10th.
Dimitris Mitropoulos
rcdim.blogspot.gr
www.the-painter.gr
Mitropoulos Jim is offline   Reply With Quote
Old 12-31-2012, 07:37 AM   #1082
Here is my setup:
http://www.petitrc.com/reglages/top/...1223/setup.pdf
The car isreallyquick and stable. You should try it.
rcdim.blogspot.gr
www.the-painter.gr
Old 01-01-2013, 04:36 PM   #1083
Autocratic's Avatar
Trader Rating: 26 (100%+)
So did some testing with the car today. Was making pretty consistent laps but I'm about 1/2 second off the pace.
Had some issues though:
-Broke the left front spool outdrive (plastic). Not really sure how though. Had a few hits with boards but nothing serious. I am running the 3Racing DCJs. I didn't shim the outdrives because I didn't think they needed it. Not sure if this effects where the driveshaft pins put load on the outdrive.
-Lost a rear driveshaft blade somehow.
-Bent the Top aluminum steering blocks on one side. I've heard these are weak, but didn't think they were that bad. I know there's another company making aluminum blocks that are supposed to be stronger. Don't know the name though.
So far I like the car, but it was used, so I guess I can't really complain too much.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 01-11-2013, 02:59 PM   #1084
TeamWTF's Avatar
Hey guys, just thought I'd update where I'm at with my tweak issues.
As posted,i found the rear bulkhead topdeck screws were out by 0.5mm, causing some serious tweak. The bulkheads were checked and fine, along with the topdeck.
So I installed a new chassis... Problem solved.
I hope this can help someone else who built the car and regretted it. My chassis was out. Im not upset, just happy its sorted.
Thank Rod from topracing Australia for great support... As always.
Now to finish the build and get it on the track!
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 01-11-2013, 03:16 PM   #1085
I have to say it never occurred to me that it could be the chassis and not the top deck that was out of alignment. Good luck with the rest of the build and enjoy.
Web Site: http://www.rcracingreviews.net
Sponsors: XFactoryUK | Serpent UK | Modeltune
scoyle is offline   Reply With Quote
Old 01-14-2013, 03:07 AM   #1086
Originally Posted by Pilotloots View Post
we tried that already remember? My Serpent kicked your T4's behind at coastal cup...
Yeh...Hope to see you try and kick them this year...
2Quick is offline   Reply With Quote
Old 01-14-2013, 03:55 AM   #1087
Bishop's Avatar
So it was the chassis for sure?, was it one of the cars from the pre-order?, cause I know the one I got always seems to have a tweak I can't quite track down, just started using my the second one I bought, and I don't think it has the same tweak issue, or it seems better.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 01-14-2013, 05:46 AM   #1088
hanulec's Avatar
Trader Rating: 23 (100%+)
I had a really good showing with my EX this past weekend. Its made me excited to run the car again.
Overall it is amazing what impact two screws in/out of the top deck at the motor mount can have. Right noe the std top deck with the front two scews in or thick top deck with no screws appears to be best in high grip carpet racing.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-16-2013, 01:50 PM   #1089
wuzi's Avatar
hi, can i have a set up for 13,5 ride tires med-high grip on carpent???
thx from austria
wuzi is offline   Reply With Quote
Old 02-07-2013, 12:45 PM   #1090
RC MARKET's Avatar
Mico Pro was release New suspension mount for EX
RC MARKET is offline   Reply With Quote
Old 02-07-2013, 11:01 PM   #1091
Born2Run's Avatar
For 38$. No thanks.I'll stay with the old suspension mount.
Whatever
Born2Run is offline   Reply With Quote
Old 02-08-2013, 02:00 AM   #1092
jumpnjack's Avatar
is the new suspension worth changing? Jerry, Larry and you using the new setup?
Awesomatix A700L, T.O.P. Rebel 10
Apex RC Pro Shop
ORCA/Pro Spec, Team EA Motorsport, Awesomatix USA, RC America, Team Powers
T.O.P Racing USA, John's BSR Racing Tires, Gravity RC, R1werks, 3Racing, TQ Wire
jumpnjack is offline   Reply With Quote
Old 02-08-2013, 05:24 AM   #1093
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
Send a message via AIM to DENNIS STORTI
I'm pretty sure we are all running the standard photon ex mounts.
DENNIS STORTI is offline   Reply With Quote
Old 02-08-2013, 05:24 AM   #1094
hanulec's Avatar
Probably nice.. But haven't tried.
Old 02-09-2013, 07:36 PM   #1095
jumpnjack's Avatar
OD, should have them soon enough!!! i'll wait for him to get them.
Apex RC Pro Shop
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 09:03 PM
SEO by vBSEO 3.5.0
