Old 11-29-2012, 10:49 PM   #1051
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Originally Posted by skypilot View Post
oooooooo, oh ok, i get it. so then can I assume that because it was mentioned that he was using the concentric inserts, there is a optional eccentirc insert.
I'm being serious, I know nothing about the TOP brand of cars. it took me two weeks to figure out I had the rear arms on different.
Our original Photon had eccentric suspension mount inserts to fine tune roll centers. With the EX suspenions you can simply add or take out spacers to change the roll centers.
Better two weeks then two months! I've seen it happen more often then one would think. ;-)
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 11-30-2012, 06:45 PM   #1052
skypilot's Avatar
Trader Rating: 14 (100%+)
Thanks EJ
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 12-01-2012, 09:47 AM   #1053
Trader Rating: 17 (100%+)
LOTS of new goodies OUT
New Front caster blocks 4 deg and 6. With bigger openings. (Im assuming the new DJS will fit)
The new steering blocks
and new rear hubs!!!!
Most can be seen on
https://www.facebook.com/#!/pages/TO...95386490589769
others are on the EX group page!!!!
https://www.facebook.com/#!/groups/115953461872420/
Looks like I'll be putting in an order with OD here shortly! I'm not sure if these are released in the US yet. OD or EJ would have to chime in!
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 12-01-2012, 03:10 PM   #1054
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Or here
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is offline   Reply With Quote
Old 12-01-2012, 08:45 PM   #1055
Professor's Avatar
Originally Posted by nnick View Post
Or here
thanks mr a morris & nick. this is great news(no more xray parts on my photon)are these goodies available yet ???
VBC RACING-R1 WURKS AUS--HOBBYWING--SILVERBACK--MAD GRAPHICS--BLITZ
Professor is offline   Reply With Quote
Old 12-01-2012, 09:14 PM   #1056
B00t13g's Avatar
Does anyone have a good/ easy to drive setup for low to medium traction carpet?
B00t13g is offline   Reply With Quote
Old 12-01-2012, 09:43 PM   #1057
The kit set up sounds like it would work pretty good. You can always check Hanulecs wiki page..
@ professor
Not sure. Usually by the time I see see them on tops Facebook page OD either just got them in or will have them in a few days.
T.O.P Racing USA
Old 12-02-2012, 03:24 AM   #1058
Originally Posted by 2Quick View Post
Mine goes well after putting some time with setup. Let me set it up for you or you can get a T4....Lol
we tried that already remember? My Serpent kicked your T4's behind at coastal cup...
Pilotloots is offline   Reply With Quote
Old 12-02-2012, 04:04 AM   #1059
Professor's Avatar
thanks mr a morris
Old 12-03-2012, 07:31 AM   #1060
RC MARKET's Avatar
TOP released New Steering Block & Rear Hub Ver.2 ,
C-Hub 4 & 6 Deg Castor Ver.2,
Low Friction & Long Life Belt
T.O.P. PHOTON EX-top-tc-mabs01.jpg   T.O.P. PHOTON EX-top-tc-mabs02.jpg   T.O.P. PHOTON EX-top-tc-macs01.jpg   T.O.P. PHOTON EX-top-po-pdt012.jpg   T.O.P. PHOTON EX-top-tc-pdt006bl.jpg
RC MARKET is offline   Reply With Quote
Old 12-03-2012, 08:29 AM   #1061
Bishop's Avatar
New C hubs look good (I hate pulling them to remove or change drive shafts), as does the rest, does the third hole in the front hubs give more steering???
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 12-03-2012, 09:46 AM   #1062
bkspeedo's Avatar
If you use the new third hole, farthest from bearing, it will create a shorter upper camber link which will give you more camber gain and make the rear of the car roll less which should loosen up the rear of the car.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 12-03-2012, 10:50 AM   #1063
hanulec's Avatar
Trader Rating: 23 (100%+)
I'll try to post my current setup. It was in only 0.25s off Larry this weekend -- and should be a bit easier to drive when grip is low. You need medium roll center arm mounts..
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-04-2012, 08:22 PM   #1064
hanulec's Avatar
my current setup just posted -> http://racerlog.com/wiki/T.O.P._Photon_EX#Setups
for the upcoming weekend i'm planning on raising my roll centers 1.5mm all around to make my car more similar to Larry's
Old 12-07-2012, 02:42 AM   #1065
Motokas's Avatar
Hello
IŽm Rui Almeida, Photon Ex Team Driver from Portugal
And can also see the news here - T.O.P. Racing Portugal (Facebook)
This is the new page I created for the pilots of Portugal and to all World drivers.
Hug to all
Rui dŽAlmeida
T.O.P. Racing Team Driver
Motokas is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 09:03 PM
SEO by vBSEO 3.5.0
