Like Tree1Likes
Old 11-26-2012, 06:02 AM   #1036
Hello, anybody that can help me with a high grip setup?
in low grip to medium grip i Always find a good setup, but for high grip tracks, or when the track becomes high grip, i never find a good setup.
thx
DW Hobbyshop
Serpent, VBC racing, muchmore racing, skyrc, nosram,...
Driving a ERYX3.0
stofke is offline   Reply With Quote
Old 11-27-2012, 09:11 AM   #1037
Originally Posted by heretic View Post
Thanks Johnny, good to know.
I just wish TOP would release their own DCJs, I don't want to spend time, money and energy trying to adapt something from another brand. Seriously could they get their priorities straight ? Releasing their super fancy servo mount when some manufacturers have had their dcjs released for more than a year, if not two. Come on.
lots I wish Top did with the EX... mine will be a drift car and if it brakes an ornament. Wish they waited and got it perfect before release.
Pilotloots is offline   Reply With Quote
Old 11-27-2012, 09:44 AM   #1038
Mine goes well after putting some time with setup. Let me set it up for you or you can get a T4....Lol
2Quick is offline   Reply With Quote
Old 11-27-2012, 10:19 AM   #1039
bkspeedo's Avatar
thx
Check out Hanulec's Wiki page, at the bottom are some setups. Start with Larry's Middle River.
http://racerlog.com/wiki/T.O.P._Photon_EX#Setups
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 11-27-2012, 10:28 AM   #1040
Robert_K's Avatar
Steve Weiss Posted this:
This will help you to give you more Steering and make the Car easier to Drive. You have to Cut the Front Arms 1,5mm to move it more Rearward! Also use the Rear Arms in the Front Pos. to get the Car in the shortest Position. Don`t forget to check the Position from the Shocks, they must be always in the Straight Position! If not, use Shims
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 11-27-2012, 12:01 PM   #1041
Skitee's Avatar
The EX was still one of the better cars in the 2012 SA Championship with 2 cars in the top 5 and 3 cars in the top 10.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 11-27-2012, 12:03 PM   #1042
Skitee's Avatar
I drove your EX and it was good then, so if you got better then it should be great
Old 11-27-2012, 04:36 PM   #1043
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Default Asphalt Setup
Hello All,
Just wanted to share the asphalt setup I've been using. It's worked well on many tracks. I'm really happy with it.
DCJ's are being made now.
Let me know if you have any questions.
Thanks,
EJ
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 11-27-2012, 05:08 PM   #1044
TeamWTF's Avatar
Originally Posted by E.J. Evans View Post
Hello All,
Thanks,
EJ
Which lower roll mounts are you using?
Cheers
Phill
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 11-28-2012, 01:47 PM   #1045
E.J. Evans's Avatar
Cheers
Phill
I'm using the "H" mount which is standard with the kit. I'm also using the concentric inserts which are standard.
Old 11-28-2012, 02:37 PM   #1046
TeamWTF's Avatar
Excellent
Old 11-29-2012, 07:38 PM   #1047
skypilot's Avatar
Trader Rating: 14 (100%+)
by concentric inserts do you mean the little metal part that slips inside the H mount,
and by concentric to you mean off set, like its high in one position and you turn it over now its in the low position??
mine are not like this.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 11-29-2012, 07:48 PM   #1048
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
Concentric means it shares the same center, ie, the inner hole and outer diameter share the same center, as in not off set. Eccentric means the centers are off set......
SLOWINSLOWOUT is offline   Reply With Quote
Old 11-29-2012, 07:52 PM   #1049
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
concentric inserts are the stock standard Inserts for EX..
OVA is offline   Reply With Quote
Old 11-29-2012, 08:49 PM   #1050
skypilot's Avatar
oooooooo, oh ok, i get it. so then can I assume that because it was mentioned that he was using the concentric inserts, there is a optional eccentirc insert.
I'm being serious, I know nothing about the TOP brand of cars. it took me two weeks to figure out I had the rear arms on different.
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 08:03 PM
