Old 10-23-2012, 05:59 AM   #976
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by Jerry P View Post
I've been running the Arrowmax T3 dcj's and they are working out quite well also.
Yes.. but that would require Mira outdrives to work in a photon.... and those are sold out
What is with the new avatar jerry? U dont like my pretty face?
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-23-2012, 12:56 PM   #977
MAD916's Avatar
My New EX is running the Arrowmax ECS's for the Tamiya 417 they work with the stock Top C-Hub's, Stock Steering Knuckles, and the stock king pin collars. also work on the stock front spool without the need for the CVD Blades the only thing not stock is you have to use a 5x10x3mm inner wheel bearing but they have held up just fine with lots and lots of packs run through them.
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 10-23-2012, 01:24 PM   #978
mazmo's Avatar
Thanx guys, all good info... lots of options.
Decided to try the HB DJC's (in original photon) and reflex racing in the EX
Cheers
Alan
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 10-24-2012, 04:53 AM   #979
Jerry P's Avatar
Trader Rating: 44 (100%+)
Because people were mistaking me for a white dude. Those who dont know you thought it was a self portrait of me.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 10-25-2012, 05:38 AM   #980
BardSmith's Avatar
Trader Rating: 59 (98%+)
Default Conversion Kit
Hey, lookie what I found.
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 10-26-2012, 08:11 AM   #981
old-man's Avatar
I saw that too and it's going for $250. Not sure what it has in the kit to justify.
old-man is offline   Reply With Quote
Old 10-26-2012, 08:14 AM   #982
MikeXray's Avatar
Trader Rating: 72 (100%+)
Any now it is!
I wish they would make a conversion to fit the EX steering and mounts onto a photon chassis.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-26-2012, 09:21 AM   #983
j.d.roost's Avatar
Trader Rating: 28 (100%+)
http://rc-evo.com/xbbs/forum.php?mod...ead&tid=272052
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 10-26-2012, 11:55 AM   #984
Originally Posted by j.d.roost View Post
where can i pick up a top battery strap
goslow is offline   Reply With Quote
Old 10-27-2012, 07:46 AM   #985
Hello,
I have a Photon EX on the way, and am transitioning from an Xray T3. I've only raced 17.5 stock blinky and have been trying to do some research in terms of what parts to get to setup for a low traction carpet scenario.
My first question is regarding the gear diff, I don't see in the manual what is recommended as a starting point for low traction but is it the same as the T3 (700-1000 cst) or do you guys recommend something else?
Finally, for a starting point on low traction carpet I'm thinking of using 324 gf/mm in the front and 289 gf/mm in the rear. Would that be too soft or are the kit springs a good enough starting point for my case?
hcw5733 is offline   Reply With Quote
Old 10-29-2012, 08:15 AM   #986
Trader Rating: 17 (100%+)
Originally Posted by hcw5733 View Post
Hello,
For low traction, I would start with the box stock set up. Its for asphalt, which should be a good starting point for low traction carpet. 700-1000 cst sounds about right. I would soak the diff o-rings in WD-40 for a few hours or a day before you assemble. It will keep them from leaking.
@goslow. Top Racing USA, or Amain hobbies will have the strap.
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 10-29-2012, 08:33 AM   #987
hanulec's Avatar
id recommend xray 2000cst for the gear diff in the rear
the ex had a nearly perfect weekend on the rug at the halloween classic. mr fairtrace TQ'd 17.5t rubber tire but had some bad luck in the race to end up 3rd. his car was blazing fast -- 0.2s quicker than anyone else on hot lap.
myself and jerry p where running a much different setup (somewhat easier to drive for us) and put the car in the B and C -- with both of us having potential for so much more if we just wouldn't blow out
this upcoming weekend we should have some more testing time and will then post up a setup sheet(s).
Old 10-31-2012, 12:12 AM   #988
TeamWTF's Avatar
Hey Guys,
I've never been happy with my EX, and may have found an issue...
The car 'seems' tweaked. When I lift an end up, one wheel sits about 4mm higher then the other. So its the left hand rear (motor side) and opposite front that have the issue. This is with a battery in the car, strap not to tight. Also, it sits perfectly on chassis blocks... flat and nice. The chassis itself is twisting differently!
ie, on blocks, I can see the chassis 'flexing' and lifting those opposite wheels (Doing the tweak test on chassis blocks)
L/R balance is perfect
I tried loosening the servo mounts and the motor mount mount screws and the layshaft screws.
This car has always hooked turning right, and I could not figure it out. Is my chassis plate stuffed? I replaced the top deck and no difference.
As said, from new I have had trouble getting this car to turn without snapping mid corner.... particularly right.
Any help appreciated...
Phill
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 10-31-2012, 01:16 AM   #989
Bishop's Avatar
Originally Posted by TeamWTF View Post
Hey Guys,
Phill
I have struggled with this myself with the EX, I'm honestly not sure if maybe there is a tweak in something I can't find, but I'm always untweaking with droop etc to get even lift/steer etc, actually I'm curious to try the floating servo mount, just in case the tweak comes from the new servo mounting layout.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 10-31-2012, 01:43 AM   #990
scoyle's Avatar
Hey Guys,
Phill
I have actually found that the Photon EX has tweaked less than previous cars I have owned but this is possible down to pure luck and hitting less...
It sounds like you have a build up of tweak which could, in my opinion, come from several different places;
Top deck
Shock towers
Roll bars
Motor mount
Servo mounting
The first thing I would do is get yourself a very flat surface (I use a piece of toughened glass). Disconnect the shocks and roll bars.
I would actually take the servo out of the car. Then loosen of the top deck screws, the screws that hold the bulkheads down and the screws holding the shock towers on.
Put the car on the glass and check that it is flat... if it isn't then you may have managed to bend a bulkhead or some alloy part of the car... in that case it is a complete strip down and check each alloy part on the glass plate to ensure that it is flat. Then start building the car back up checking on the glass after you put each part onto the car to see if it changes.
But hopefully you do not have to go that far... start by re-tightening the upper bulkhead parts (that the shock towers attach to) and then tighten the shock towers... check still flat. Next get a friend to push down on the shock towers to keep the chassis flat as you tighten the top deck screws starting at back right screw, then front left, rear left, front right, tightening diagonal screws... check still flat...
For the servo I would recommend the new floating mount but for the current mount loosen of the screws that attaches the servo and put the servo back in place, tightening the screws that attach it to the chassis. Then put a thin piece of car between the servo and the chassis and tighten the screws holding the servo to the servo mounts (the card holds the servo off the chassis by a tiny amount)... remove the card when the screws are tightened... guess what... check still flat.
Now attach the roll bars and check (one of those could be bent) and finally attach the shocks again.
I check my car for tweak after each run and very rarely do I have to do anything other than loosen the top deck screws and then re-tighten.
Hope this helps and you get sorted...
Stephen
Web Site: http://www.rcracingreviews.net
Sponsors: XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 08:03 PM
