Like Tree1Likes
Old 09-21-2012, 07:58 AM   #886
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Im at 1330 with Lunsford Titainium screws, Hand made ackerman extneders, LW arms, Xray ECS, Stiff chassis and topdeck. Hacker Speedo, Spektrum 3520 reciever, Spektrum 6040 servo.
Solaris Tires and wheels. LW Ltcr
My battery weighs about 320 grams.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 09-21-2012, 08:11 AM   #887
That hobbywing v3 is heavy, 90-something grams according to specs. A tekin RS is 27g w/o wires, but it's very light. Don't know about the hacker.
-Mike
Old 09-21-2012, 10:24 PM   #888
tha Beast's Avatar
Trader Rating: 100 (99%+)
shameless plug here but I gotta get rid of this thing
Top Photon EX
REFLEXRACING
MIKES HOBBY SHOP PORTER TX
tha Beast is offline   Reply With Quote
Old 09-22-2012, 07:39 AM   #889
Originally Posted by Skitee View Post
The TOP rims are very firm.
Thanks... Will give them a go...
Corally PHI/PHI 09 TEAM DRIVER
BMI DB12RR TEAM DRIVER
TOP
LRP TC SXX, LRP SXX Ver. 2, LRP X12 Octa, Futaba 3PKS Spektrum Module, Protform.
SOUTH AFRICA :)
PHI/BMI racer is offline   Reply With Quote
Old 09-24-2012, 03:45 AM   #890
Mitropoulos Jim's Avatar
Originally Posted by Jerry P View Post
What weight do you run? Both my ex's are around 1355. We run 1380 as our weight.
Mt ex is 1415gr ready to run with lw body
Dimitris Mitropoulos
rcdim.blogspot.gr
www.the-painter.gr
Mitropoulos Jim is offline   Reply With Quote
Old 09-24-2012, 04:23 AM   #891
Default T.O.P Photon EX First Impressions
Well, on Saturday the weather was finally ok, so I managed to get to our local track to test my new photon ex for the first time.
I started with kit setup , and from the first run I was impressed with the car having tons of steering!
After the first two runs, with minor setup changes, I ended up with a car really quick, very easy to drive and forgiving almost all my mistakes! I was on very good pace, just on my 3rd run with the car and really enjoed driving it!
Uploaded with ImageShack.us
Now,after 10 runs, It is time for the first rebuilt, just to check that everything is in place and that there are no wears on the car.
Can't wait for next weekend's first race with my photon ex!!!
I am starting to get really excited!
Stay tuned!
rcdim.blogspot.gr
www.the-painter.gr
Old 09-24-2012, 04:35 AM   #892
Here is my setup
rcdim.blogspot.gr
www.the-painter.gr
Old 09-24-2012, 09:42 AM   #893
My car sits at 1290g with LW body, titanium screws (besides chassis plate), SP cirtix esc and v3 motor, Muchmore 5600 lipo's, belt tensioner and heavy (handout) rims. These could be 10-20g lower in total. Also installed alu turnbuckles, LW wishbones and smaller alu ball ends/cups. I did removed the fan from esc and shortened all wiring. Still a full functional car ready to race and very durable. Didn't broke or bend anything with outdoor racing, ran the same set-up on the old Photon. I could shave off more with other batteries, thinner power-cables (13AWG perhaps). In other words, I did removed as much a I could so far and added it back to bring the car up to 1350g. I made a solid brass battery locator (in the middle) and added more weight close to the center of the car as low as possible. Took away alot of weight from suspension and from high positions in car. Still looking for titanium set-screws. Anyone know were to find? Photon's suspension is drowned with it...
koney is offline   Reply With Quote
Old 09-24-2012, 05:47 PM   #894
Trader Rating: 17 (100%+)
Brand new alluminum shock bottoms available at TOP racing USA
Yes, they will make your car faster
sorry for the crappy picture
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 09-24-2012, 11:24 PM   #895
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Mine did go faster
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is offline   Reply With Quote
Old 09-24-2012, 11:51 PM   #896
*SBH*'s Avatar
Hi Jim
If You buy the Alloy suspension mount inserts, You will save app. 16g
Part number PO-PXSU001RD. I bet Your servo is very heavy as well. My servo weighs 22,5 gram and yes, its strong enough.
By the way, super nice detailed explanation from the assembly of Your car, I really like that.
Good luck
Søren Boy Holst
Denmark
*SBH* is offline   Reply With Quote
Old 09-25-2012, 12:22 AM   #897
Originally Posted by *SBH* View Post
Hi Jim
Good luck
Søren Boy Holst
Denmark
SBH I am glad you liked my presentation.
My servo is a futaba BLS 551, 44gr!!!Really heavy
I have the lw suspension arms, and aluminum turnbukles.
My transponder is the old red amb one, and have added a 30mm fan behind the motor, two small bodyposts on the rear shock tower and two belt tensioners.
I think the photon ex is a heavy car and I don't know if its worth to buy all the optional parts gust to make it lighter. What else would the Alloy suspension mount inserts be better at?
rcdim.blogspot.gr
www.the-painter.gr
Old 09-25-2012, 12:37 AM   #898
*SBH*'s Avatar
Hi again
The weight also depends a lot on the inserts in the tires. Indoor with foam inserts the car is a lot lighter than with the rubber inserts from outdoor. The suspension mounts only has 1 purpose, to guide the screw that holds Your arms to the mounts in the car. So they dont have to be steel. You save app. 2g pr mount = 16g. The old AMB transponder to the new will save app. 7g
I dont know the weight of Your receiver, but mine is 7g.
The batteri is an important factor as well. You can easily save 35g by changing battery, if You need it. Last but least, the paint of the body can also vary 20g or more. My body weights app. 82g
Søren
Old 09-25-2012, 03:04 AM   #899
Hi again
Søren
Thanks again Soren,
I 'll come up with more details on the wight of all my equipment.
Dimitris
rcdim.blogspot.gr
www.the-painter.gr
Old 09-26-2012, 07:07 PM   #900
abi787's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to abi787
Cool Photon Titanium
Hi,were can I find a set of TITANIUM screws for the TopPhoton.
abi787 is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 08:03 PM
