Old 08-28-2012, 02:40 AM   #826
*SBH*'s Avatar
Default T.O.P. Photon EX - Champion
Hi guys.
Here is some nice reading http://www.redrc.net/2012/08/soren-b...on/#more-57834
I really love this car
For those who want more info, here is the equipment used:
Car - T.O.P. Photon EX
Speedo - GM Genius 75
Batteri - GM VIS 70C 6800mAh
Motor - Team Powers 17,5t or TP 17,5 (depending on the track)
Servo - Bluebird
Transmitter - Graupner JR1 with Spektrum micro receiver
Tires - Solaris Hard
Sponsors - RC Models - T.O.P. - GM-Racing
Anything else, please feel free to ask :0)
Søren Boy Holst - FWD Euro and World Champion in 1996 - Started racing RC Cars 13 years old 24/1-1990
*SBH* is offline   Reply With Quote
Old 08-28-2012, 10:55 AM   #827
Trader Rating: 17 (100%+)
Awesome man
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 09-02-2012, 12:30 AM   #828
Bishop's Avatar
The way you guys run your cooling fans seems surprisingly effective (I double sided tapped a Yeah Racing blowing back onto the motor), I don't usually bother on my 10.5 racing at night here, but I set up a fan on the chassis powered off the battery cause I'll be running 17.5 during the day soon.
Testing it on Friday night, I was very impressed by just how cool the motor stayed, I set some good lap times with the 10.5 running under 50C or so, timing up around 35 on the Thunder Power, so I figured I'd go up a tooth.
But on the track layout we were running, I went slower, even when I upped the timing to 40 I did not match my lap time with a tooth smaller.
It's possible (I'm guessing a little here, still not that experienced with electric) I may have geared past what my Turnigy Nano Tech 5600 was able to keep up with punch wise, cause I felt like I lost a bit of punch.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 09-03-2012, 03:07 PM   #829
mymax's Avatar
Hi,
I don't have the car yet (should arrive this week) and i have some questions for you..
Can you tell me what is the Internal Gear Ratio ?
I will run 17.5 blinky, ballistic motor (house rule) and have to target 4.15 to 4.20 fdr.
I am already equipped in 64pitch and have to find a spur to acheive the fdr...
I already have a complete Hpi spring set, does these spring fit on the Photon shock?
Can you tell me if a double joint cvd exist for this car?
mymax is offline   Reply With Quote
Old 09-03-2012, 03:58 PM   #830
Luppi Stefano's Avatar
Originally Posted by mymax View Post
Hi,
Can you tell me what is the Internal Gear Ratio ? 2
I will run 17.5 blinky, ballistic motor (house rule) and have to target 4.15 to 4.20 fdr. look the Hanulec wiki page
I already have a complete Hpi spring set, does these spring fit on the Photon shock? Fit perfect! is similar to TOP Spring
Can you tell me if a double joint cvd exist for this car? ECS Xray, With Mira Outdrive, look Hanulec Wiki
hanulec wiki T.O.P. PHOTON EX
for Double Joint, I watch Yokomo Sper-R or Yokomo on Steven Weiss, TOP Racing Europe Driver
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 09-03-2012, 06:16 PM   #831
mymax's Avatar
Thanks for the info..
Old 09-04-2012, 09:30 AM   #832
Hi
Spec-R Yokomo Shafts works great on the EX. But you must use the Yokomo wheel hub. And cut a little bit from the C-hub (inner diameter)
Regards
Sandro
Stanmarsh is offline   Reply With Quote
Old 09-05-2012, 05:52 AM   #833
Bishop's Avatar
Can anyone please let me know if I may or may not need anything bigger than a 38T pinion (48p) for 17.5 blinky class?, I have like 15-38 tooth range in my kit, and I put a 66T spur on today, but I'm in the middle of a last min order with around a week till my event, with zero experience in 17.5, and no idea how low I may need to gear?
QRCCRA
www.qrccra.org.au
Old 09-05-2012, 06:53 AM   #834
Jerry P's Avatar
Trader Rating: 44 (100%+)
Depending on how crazy you get your FDR can get to the low to mid 3's.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 09-05-2012, 07:37 AM   #835
the 38T will put you at a 3.4 FDR so you should be fine. Depending on motor and track I would start around 3.8 FDR (66/35). If your running a revtech put it at a 4.0(66/33)
If you see the factory smoke, I take no responsibility
T.O.P Racing USA
Old 09-05-2012, 08:28 AM   #836
Bishop's Avatar
I probably should have mentioned it's a Thunder Power 17.5, I have like the 10.5 TP and like it (for many reasons), so figured I'd get their 17.5T.
When I was swapping in the the 17.5 today I threw in a 66/33, and realized I was missing my 36T, so figured I'll order a replacment, with the question mark being should I also grab a 39 and 40T.
QRCCRA
www.qrccra.org.au
Old 09-05-2012, 01:44 PM   #837
scoyle's Avatar
I did a bit of a blog entry on my first indoor run with the Photon EX...
http://rcracingni.co.uk/?p=34907
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 09-05-2012, 02:09 PM   #838
I dont think you will need that big a pinion with a thunder power. I believe my buddy was right at at 3.8 with his. He tried to go a little more and the factory smoke came out to play.
Just start conservative and temp it as you go. I personally dont think you will need a 39 or 40 though.
T.O.P Racing USA
Old 09-06-2012, 02:12 AM   #839
Mitropoulos Jim's Avatar
Hi all, I just purchased a brand new photon ex from www.rcring.eu and am really excited with the car!!!
I will start building the kit on Monday, so until then, is there anything I should know, any building tips?
Can I fit a 116/64p spur gear?
I will post photos and review when I am done, stay tuned!
Mitropoulos Jim is offline   Reply With Quote
Old 09-06-2012, 02:23 AM   #840
scoyle's Avatar
Welcome aboard, you won't be disappointed...
Best place for tips is http://racerlog.com/wiki/T.O.P._Photon_EX and I have just done a review and a few blog entries on my site at http://www.rcracingni.co.uk
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 08:03 PM
