Old 07-13-2012, 04:58 AM   #721
Skitee's Avatar
Originally Posted by Pilotloots View Post
big fan of the Top Racing brand. Owned a Scythe, Photon, Sabre, Rebel and now busy with the EX. First page of build, shims missing?? wtf, after searching for an hour figured they not there. Now I have everything on the chassis and already stripped 2 screws using decent tools.
I hope all this frustration is worth it in the end.
When you get the EX on the track you'll notice the improvement over the old car straight away.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 07-13-2012, 08:03 AM   #722
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by vadersing View Post
Can we know the size of the flange bearings please. Eager to try this.
2 3X6X2.5 mm
4 5X8X2.5 mm
...to order to get the slop out it to shiming just right. Make sure the both side shiming are the same .This is No half fast job lol
OVA is offline   Reply With Quote
Old 07-13-2012, 09:12 AM   #723
anyone using new option from TOP?
asuradahk001 is offline   Reply With Quote
Old 07-13-2012, 10:37 AM   #724
OVA
OVA's Avatar
like what?
Old 07-17-2012, 06:41 PM   #725
hanulec's Avatar
Trader Rating: 25 (100%+)
Hi all - I just recorded my current setup with Solaris Hard tires. My car was amazing last Saturday - June 14 2012 - in 13.5 at Jackson RC. I tried a few different spring combos during racing -- and I like 367 front, but I'm going back and forth between 324 and 306 rear springs.
I made a pass for the lead on the first lap of the A-main putting the moves on Larry. I head the lead for another lap, with us both giving it all we had -- making similar mistakes, over driving a section of the track we refer to as "The Member" on lap two. We both synchronized failed on the start of lap 3 rolling our cars off the sweeper entrance corner. After a lot more failure by everyone else I made a pass for 2nd on the second to last corner, and was right behind Larry at the stripe. A very exciting race -- but a ton of failure all around.
This was the first time I ran 367/324 springs in the main. It had a really good feel -- gave me a little too much confidence. I had tried 344/324 in round 3 -- the car felt great, but would roll over on itself with every curb. In round 2 with 367/306 I had one of my best runs with the car ever only fading 0.15s over the top 20.
http://racerlog.com/wiki/T.O.P._Photon_EX#Setups
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-17-2012, 06:52 PM   #726
artwork's Avatar
Trader Rating: 56 (100%+)
I love how you leave out the pinion on every setup...what are you trying to hide mike?
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 07-17-2012, 06:54 PM   #727
hanulec's Avatar
my big race slowness
your the motor fast guy from what i hear....
Old 07-17-2012, 07:52 PM   #728
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I think Hanulec screwed up his most recent setup some on that setup sheet but I'm not sure.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 07-17-2012, 09:22 PM   #729
bkspeedo's Avatar
Larry wheres your setup? I'm sure you were just toying with FJ, everyone needs a confidence builder now and again.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 07-17-2012, 11:31 PM   #730
Trader Rating: 15 (100%+)
Default Pinion
If you saw how many motors he smoked at the reedy you would be happy you don't know what he runs!!
AARON YOUNG is offline   Reply With Quote
Old 07-18-2012, 02:58 AM   #731
RC MARKET's Avatar
Which parts ?
this one ?
RC MARKET is offline   Reply With Quote
Old 07-18-2012, 03:44 AM   #732
hanulec's Avatar
+1
Old 07-19-2012, 09:59 AM   #733
bkspeedo's Avatar
The Ackerman setting people are posting in there setups does not seem right, 1mm shim between rack and ball stud? This would angle the links back slightly which is not desired.
Has anyone tried 3mm of shims with the V2 alu blocks, slightly angles the links forward? It's dialed, gives you a ton of corner speed and the tires don't overheat. I run the same lap times from beginning to the end.
Brent Klingforth
Old 07-19-2012, 10:13 AM   #734
S.Stew's Avatar
My problem with the car so far has been loose off power so in my opinion decreasing (moving links forward) is directionally incorrect.
S.Stew is offline   Reply With Quote
Old 07-19-2012, 10:31 AM   #735
bkspeedo's Avatar
If your car is loose theirs other things to look at.
Roll center front and rear, springs, shock oil, etc. Have you posted your setup? if not, post it and we'll give you some suggestions.
I will say my car's current setup is not easy to drive for those that like to shoot into the corner, it will be loose. But if you drive it smooth it's very fast and easy to control. So some of it is driving style.
Brent Klingforth
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 08:03 PM
