Like Tree1Likes
Old 07-05-2012, 06:36 PM   #706
S.Stew's Avatar
Originally Posted by OVA View Post
is you EX loose on power or off power?
Mostly off power, too aggressive turn in seemed to cause snap over steer.
S.Stew is offline   Reply With Quote
Old 07-05-2012, 07:02 PM   #707
hanulec's Avatar
Trader Rating: 27 (100%+)
Did u try lengthening the rear wheelbase
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-05-2012, 07:07 PM   #708
S.Stew's Avatar
No, but I will!
Would you keep the front wheelbase short?
Old 07-05-2012, 07:20 PM   #709
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
No, but I will!
Just me ..I would lengthening the front wheelbase first...
hanulec right ..lengthening the rear wheelbase would works as well..
OVA is offline   Reply With Quote
Old 07-05-2012, 08:12 PM   #710
hanulec's Avatar
I've kept the front wb short so far..
Old 07-05-2012, 09:15 PM   #711
OVA
OVA's Avatar
reason to keep the short wb for more steering ?
or it is for low speed steering ?
Old 07-05-2012, 09:27 PM   #712
mazmo's Avatar
Mine was very loose first time out. Kit setup except for shortened front end (all shims in front of hinge pin). I went to 286 rear spring, not much help.
Next time out I'm going to go back to longer wheelbase and go to 3* rear toe.
Mine was also loose in rear, good now. Main changes I made were:
  • Stand up rear shocks one hole
  • Same sway bar front and rear (1.2mm)
  • Lengthen front camber link (inner position on camber plate) + increase spacers to 2.5mm.
  • Same springs front and rear TOP 306 (17lb)
These changes address 'loose' rear end, I'm running 17.5 boosted and rubber tire / low grip asphalt.
If you are really struggling for grip, try lengthening rear camber link to inner hole on camber plate.
Good luck with it !
Cheers
Alan
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 07-06-2012, 05:17 AM   #713
hanulec's Avatar
I was fighting a push initially so I kept the front short.
Provides the most ackerman adjustability otherwise the steering links start to get too close to the arm mounts. 1mm Max shim could be possible in the front end.
Old 07-06-2012, 01:01 PM   #714
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Or reduce rear droop
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is offline   Reply With Quote
Old 07-10-2012, 05:05 PM   #715
S.Stew's Avatar
Just want to Thank OD for pretty awesome customer service. New collars on the way! Thanks again man...!
Old 07-12-2012, 09:55 PM   #716
OVA
OVA's Avatar
Originally Posted by Bishop View Post
I'm very keen to know what they did.
Fix the sloppy steering
mine seem to be working pretty good...No slop
you need to get 6 flange bearings and you have to add small shims for in side between the bearing and flat washers...I can tighten screw down with no problem...
PS the total of shim have to be perfect thickiness
Old 07-12-2012, 11:15 PM   #717
vabroom's Avatar
Okay, the EX has been out for a few months now. Deciding whether to upgrade or not. Besides the sloppy steering and shock spring collars, what are the pros and/or cons of the EX.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 07-13-2012, 12:31 AM   #718
vadersing's Avatar
Can we know the size of the flange bearings please. Eager to try this.
vadersing is offline   Reply With Quote
Old 07-13-2012, 12:51 AM   #719
Default EX
big fan of the Top Racing brand. Owned a Scythe, Photon, Sabre, Rebel and now busy with the EX. First page of build, shims missing?? wtf, after searching for an hour figured they not there. Now I have everything on the chassis and already stripped 2 screws using decent tools.
I hope all this frustration is worth it in the end.
Pilotloots is offline   Reply With Quote
Old 07-13-2012, 03:07 AM   #720
Bishop's Avatar
Missing diff shims, suspension arms are shimmed .5mm short, yes shock collars and sloppy steering, and screws are still not all quite fantastic quality.
But, generally it's got good build quality where it counts, and the EX develops a heap more rear end traction and steering out of the box than the original Photon did.
After driving mine a while now, I also dig the new motor mount, the sort of floating spur drive pin in kind of neat, diff is good once it stops leaking, fine adjustment things around the car are also good (sway bar locater etc).
Spur gear and pulley though is harder to get out then in the old model, apart from most related to it, those new forks that center the sway bar stop you being able to slip off the belts, also I don't like the lack of a 'neat' battery strap option, and to be really honest it's just got too many holes related to servo mounting, if I did cut down the 'bump' I'd just have an ugly half screw hole, which is dumb.
None of that take away from it being a great car though.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 08:03 PM
