Like Tree1Likes
Old 06-18-2012, 03:59 AM   #646
mario_vk's Avatar
Originally Posted by hanulec View Post
Stick w/ the spool.
Post your setup - including tire, tire prep, and track surface. We should be able to get you pointed in the right direction.
Oh, I'm sorry.
Basicly, my setup is the "standard" given by TOP--> http://www.top-racing.jp/Eng+JP/Inde...td%20setup.pdf
Only a few variations:
OIL WEIGHT: 50wt/40wt (F/R)
Shocks with about 75% rebound.
Used tires: Nosram VTEC 30R (controlled tire). Tire tweak additive (Full F/R)
Surface: Asphalt, medium grip. Medium-long track layout with a low speed technical zone.
I tried with softer front spring, shorter front axle (wheelbase), lifting rear shocks & falling front shocks, shorter front width, 2000cst silicone in rear gear diff........
nothing was succesfully.
B.R
Mario.
P.D: Congratulations for your very useful wiki
mario_vk is offline   Reply With Quote
Old 06-18-2012, 08:14 AM   #647
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
Originally Posted by mario_vk View Post
Oh, I'm sorry.
B.R
Mario.
OVA is offline   Reply With Quote
Old 06-18-2012, 12:34 PM   #648
hanulec's Avatar
Trader Rating: 27 (100%+)
I've never seen the Nosram VTEC 30R (controlled tire). What is it similar to? Does it have a low pro or high side wall? What is the rubber like? Spec jacos/solaris? Sorex?
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-18-2012, 03:16 PM   #649
Luppi Stefano's Avatar
this tires is different to all tires on market, high side wall, 65mm diameter.
good for low temperature.
used at 2010 Words' and 2011 Euro's
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 06-18-2012, 03:52 PM   #650
hanulec's Avatar
Maybe the posted reedy race setup using high profile team power tires might so the trick then...
Old 06-18-2012, 04:15 PM   #651
after building my new ex, i noticed a slight pull to the right on heavy acceleration.now after 3 race days it is almost a full right turn on accel. My setup i am using is Mike Hanulecs low traction asphalt set up. I have checked all the cvd's, all the bearings have been removed ,checked ,cleaned and lubed.Cleaned the rear diff and installed fresh 2000 wt oil....what am i missing ?
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 06-18-2012, 05:04 PM   #652
Team powers tires is Very similiar to Ride, but maybe it works, how to start setup!
Lab F1-01
Old 06-18-2012, 05:07 PM   #653
Front spool broke...see this!
or check belt, center pulley
Lab F1-01
Old 06-18-2012, 06:47 PM   #654
Thanks Luppi ! Will check as soon as possible.
Old 06-19-2012, 12:27 AM   #655
mario_vk's Avatar
Oh, sorry, I did a mistake , the tires are Nosram VTEC 30X (X, not R).
These are: http://www.nosram.com/en/products/vt...-4pcs/details/
In Spain we've using this tires for 2 years on Nationals & Regionals Championships.
B.R.
Mario
Old 06-19-2012, 12:40 AM   #656
Bishop's Avatar
Those California boys have figured this out -- they just need to post up how they did it. I have a fist full of flanged bearings from them, but I haven't attempted to fix it yet.
I'm very keen to know what they did.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 06-19-2012, 06:39 AM   #657
Well...i took out the front spool and removed the outdrives and carefully inspected the flange on both sides of the spool and saw no evidence that the spool is not working correctly.Also replaced the center pulley alloy instead of plastic...
think i will replace all the bearings tonite and see what happens...
Old 06-19-2012, 09:10 AM   #658
let us know if everything is ok
Lab F1-01
Old 06-19-2012, 09:25 AM   #659
S.Stew's Avatar
Just installed the aluminum rear hubs and notice a considerable increase in slop both at the a arm and at the axle (bearings). Normal? Go back to plastic? Thanks
S.Stew is offline   Reply With Quote
Old 06-21-2012, 03:03 AM   #660
mario_vk's Avatar
Hi!.
I'm trying to mount 46mm steel drive shafts in the rear end. Anybody knows what is the min. arm spacers needed for fit them?
I tried with RF=2.4mm and RR=4mm (makes 2 toe-in) and fits ok, but it seems a bit wider rear end.
Mario.
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 08:03 PM
