Old 06-01-2012, 09:04 AM   #586
locked's Avatar
Originally Posted by L.Fairtrace View Post
Do any cars have built in servo savers? I know the Xray, Tamiya, and Hotbodies do not.
T3 2012 comes with their extra stiff servo saver. Not "built in" like those steering post kind, but it is included in the kit. Best servo saver I've used so far. I think you need something super stiff like these for east/west servo configurations.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 06-01-2012, 09:14 AM   #587
haywood's Avatar
Trader Rating: 48 (100%+)
Default Servo saver
I woke up grumpy bear!
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 06-01-2012, 10:22 AM   #588
Bishop's Avatar
Servo savers are a mixed bag from what I have seen, TC6/6.1 comes with a nitro style saver, everything else I think does without.
Problem with them, is many turn your steering to mush, but that is subjective, I know some won't run with anything but solid, some glue up even the tightest designs.
Me, I was using the Top/Kim job, but actually hated how it felt once I got faster, then removed it, loved that, but then jumped some teeth in the servo.
As of my EX I got a Tamiya high torque saver, which I think is very simular to the Xray one, and so far I like it.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 06-01-2012, 10:30 AM   #589
RC MARKET's Avatar
Originally Posted by hanulec View Post
RC MARKET is offline   Reply With Quote
Old 06-01-2012, 10:33 AM   #590
Johnny Than's Avatar
Trader Rating: 91 (100%+)
Do you guys find that using the servo saver, one similar to X-ray, does not give enough steering throw to allow nuckles go from lock to lock? Mine is a little shy from going lock to lock with the X-ray servo saver, but when I tried the servo horn that comes with the kit, the nuckles can go lock to lock.
Johnny Than is offline   Reply With Quote
Old 06-01-2012, 03:58 PM   #591
TeamWTF's Avatar
Using a servo saver (xray, chunky one) I had to turn the steering up to around 150%. With the kit horn (that sounds wrong ) down to about 120% I think. Its all about the distance from the ball to the center of the servo spline. Longer=more steering throw for same degrees of servo rotation. Most servo savers simply are not large enough...
On that note, when using the V2 steering blocks and the 3rd hole, do you have to use the outer/long hole on the servo horn? And how will the 3rd hole change the handling of the car?
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 06-01-2012, 10:21 PM   #592
I did have to use the outer hole on the servo saver. And by mounting steering linkage on 3rd hold of v2 nuckles, it changes steering ackerman.
correct me if I'm wrong someone, but By mounting on third hole vs 1st or 2nd you would get more ackerman. Therefore, you get more steering (more reactive) because the angle of the outside wheel is more?. Similarly to adding more shims in the middle of the two bell crank. More shims=more ackerman.?
Old 06-02-2012, 05:03 PM   #593
TeamWTF's Avatar
Currently soaking gear diff O rings in WD-40 to soften them. If this no worky, I try different O rings!
Old 06-02-2012, 08:23 PM   #594
stiltskin's Avatar
Trader Rating: 101 (100%+)
Another great day with the new car. Made a few small adjustments and knocked off another 2 tenths from the hot lap. The car continues to impress with how easy it is to drive.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 06-03-2012, 01:24 AM   #595
hanulec's Avatar
Trader Rating: 23 (100%+)
wheres your setup?
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-03-2012, 08:11 AM   #596
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
New Photon EX
I E-mail twice to Top Racing and I'm not getting any response back,I ask them to put my names on the list for the new Phonton EX..what up with the?
OVA is offline   Reply With Quote
Old 06-03-2012, 09:07 AM   #597
stiltskin's Avatar
Originally Posted by OVA View Post
New Photon EX
I know that they have been quite busy preparing for and participating in the Reedy race for the last few weeks. I'm sure they are trying to catch up with all the emails that have backed up over this time. You can always give them a call. (650) 583-8898
Tony Rumple
Old 06-03-2012, 09:36 AM   #598
haywood's Avatar
Default Tony
Are you running the Hudy ecs shafts and such on your car?
Old 06-03-2012, 09:39 AM   #599
stiltskin's Avatar
Yes I am. I liked them on the original car, so I built the EX with them from the start. 50mm ECS with SPR Mira outdrives.
Tony Rumple
Old 06-03-2012, 02:55 PM   #600
stiltskin's Avatar
wheres your setup?
File is too large to upload. I can email it to you.
Tony Rumple
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 08:03 PM
