Like Tree1Likes
Old 05-02-2012, 07:30 PM   #391
stiltskin's Avatar
Trader Rating: 102 (100%+)
Originally Posted by mr.ng View Post
Thanks again
Nice work. Very simple and effective.
I weighed my car today at 1366 with full weight body, aluminum knuckles and rear hubs, Xray ECS. Electronics: Futaba 9551, Futaba 614 receiver, Tekin RS Pro, Duo3 4.5, dual SPR fans, and OHP 65c 6000mah battery. Car is a little heavy on the battery side, so I'll be adding weight to balance and going with a lightweight body for racing. Far from being overweight.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 05-02-2012, 07:30 PM   #392
hanulec's Avatar
Trader Rating: 27 (100%+)
Made the necessary modifications to the steering rack tonight - https://picasaweb.google.com/racerlog/PhotonEX
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-02-2012, 08:02 PM   #393
Good, I like the Steering rack modificati​on
mr.ng is offline   Reply With Quote
Old 05-02-2012, 08:11 PM   #394
hanulec's Avatar
Thanks. In the picture of the rack 'arm' fully extended you can see the arm hitting the cross member. I'm think about grinding that a bit too.. to get even more throw. Maybe next week...
Old 05-03-2012, 12:38 AM   #395
smilekt's Avatar
any one can give review .. old photon vs new photon EX .. thank for help
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 05-03-2012, 07:18 AM   #396
hanulec's Avatar
I think you'll have to wait a few weeks for an unbiased review . My thoughts are:
Top 3 good things
G1- no more 2.5mm screws! 3mm screws are of higher quality than before
G2- spur lay shaft and high top deck allows for easy pinion and spur swapping
G3- gear diff
Top 3 "room for improvement" items
B1- plastic steering knuckles -- I've never liked them, TOP is reworking them now. Best option until them is the aluminum v2 knuckles.
B2- few shades of red -- some of the aluminium parts have slightly different anodising
B3- the steering servo "nub" on the chassis -- just cut it off and replace it with tape or shoe goo
OVA likes this.
Old 05-03-2012, 07:59 AM   #397
part-time racer's Avatar
On the side of the EX, i would suggest:
  • build quality is a big improvement over the photon
  • screws are of a better standard
  • gear diff as standard in the kit
  • the gear diff is the best on the market ( except maybe the awesomatic?)
  • car in basic set-up (as instructions) is really neutral to race making it ideal to hone to personnal preferences
  • great to work on
  • looks excellent!!
On the Photon side:
  • the car has been around for a few years and there is loads of set-ups available to try
  • spares are still readily available
  • performes really well on carpet surface with rubber tyres
  • better adjustment on the steering links with ankermann adjustment
also forget to say that the photon makes an excellent wet car with its 6 cell chassis fitted.
part-time racer is offline   Reply With Quote
Old 05-03-2012, 09:02 PM   #398
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Originally Posted by part-time racer View Post
On the side of the EX, i would suggest:[LIST]
Not to mention a vta monster with the 6 cell chassis . Wouldnt have another car to run vta with
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 05-03-2012, 10:12 PM   #399
Send a message via AIM to kyle478
Default Photon EX
Photon EX Reedy Race Ready
Hacker Brushless USA www.hackerbrushless.com
Aero-Model www.aero-model.com
kyle478 is offline   Reply With Quote
Old 05-03-2012, 10:15 PM   #400
Default Photon EX
Photon EX
Old 05-03-2012, 11:47 PM   #401
TeamWTF's Avatar
My gear diff is still leaking... Much less then before I greased the o rings but still enough. After a day sitting in the car there is a noticeable amount of oil on the case (pulley side outdrive the main culprit, other side is OK)
Very annoying.... I have 2 spec r diffs that don't leak. If I cant sort this out I will keep using those
On a positive note, I did the velcro mod! Mine is a little different, I left the TOP velcro in one piece and ran the loose end through the slot in the batt. brace.
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 05-04-2012, 03:51 AM   #402
Ice_nl's Avatar
Send a message via MSN to Ice_nl
My top photon EX
RC-Models.nl | Shepherd Velox V8 EC OM-Edition | Shepherd Velox F1 | Buri Racer E1.2 | Tamiya 419x
Ice_nl is offline   Reply With Quote
Old 05-04-2012, 04:37 AM   #403
smilekt's Avatar
Top 3 good things
G3- gear diff
  • great to work on
  • looks excellent!!
On the Photon side:
Thank Hanulec & Part time racer for detail explanation
for now im already using photon for long time almost 3 year .. im a big fan of TOP Photon
im looking if the photon EX can give more great handling on track compare top photon..
Old 05-04-2012, 05:21 AM   #404
hanulec's Avatar
that is what i like to see and here. what classes are you running at the Reedy?
Old 05-04-2012, 05:22 AM   #405
hanulec's Avatar
the car has shown itself to be faster on carpet for Larry. i've only run my car once -- so i need a lot of more setup time. the car should be better -- but only time will tell.
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 08:03 PM
