Old 04-29-2012, 11:13 PM   #361
smilekt's Avatar
Originally Posted by Luppi Stefano View Post
very good information! Sunday test with 5.5t on asphalt mixed track
post the result .. let me know ..
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 04-29-2012, 11:40 PM   #362
Bishop's Avatar
Sweet...
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 04-30-2012, 01:26 AM   #363
Bishop's Avatar
You know sitting here building the Photon rear gear diff, the gears in it look increadably simular to my Mugen MTX5, in fact I'm fairly sure I could use the Mugen silicone oring on the outdrives...
QRCCRA
www.qrccra.org.au
Old 04-30-2012, 05:11 AM   #364
pmc
Hello
Some useful information:
Mount positions in comparison with the two Photon´s.
Photon "M" mount (low insert position) = Photon EX "H" mount (without shims)
Photon "M" mount (high insert position) = Photon EX "H" mount (+ 0.5mm shim)
Photon "H" mount (low insert position) = Photon EX "H" mount (+ 1.0mm shim)
Photos "H" mount (high insert position) = Photon EX "H" mount (+ 1.5mm shim)
Best regards:
Pedro Silva
pmc is offline   Reply With Quote
Old 04-30-2012, 06:19 AM   #365
*SBH*'s Avatar
Originally Posted by pmc View Post
Hello
Best regards:
Pedro Silva
Thanks a lot Pedro
That was really nice to know, now I dont have to measure it
*SBH* is offline   Reply With Quote
Old 04-30-2012, 06:54 AM   #366
hanulec's Avatar
Trader Rating: 25 (100%+)
Pedro - how did you measure this? Did the measurement take chassis thickness into account?
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-30-2012, 06:56 AM   #367
mazmo's Avatar
Just weighed my EX.
1430 grams race ready (rubber tyres).
Well above our max race weight 1380 grams
I have all alloy options installed and yeah racing twin fan.
Using regular weight LTC-R protoform body.
Anyone else 'over weight'?
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 04-30-2012, 06:59 AM   #368
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
IMO Running anything but a Lightweight body is an awful decision.
LW bodies are worth .1-.2 per lap plus 30 or so grams.
Either way my car is 1389 with 50 grams of weight on it but I have small electronics.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 04-30-2012, 07:41 AM   #369
mazmo's Avatar
Thanks Larry,
My electrolics are also quite small, Tekin RS Pro, low profile KO servo, mini Ko receiver, MRT transponder.
I have a heat sink with twin fans and 5800 mah lipo, could these be adding the weight.
My old Photon - with Exotek chassis- was 1380 with all the same gear / body as above .... except for alloy steering knuckles, c-hubs and centre pulley.
Thanks Alan
Old 04-30-2012, 07:46 AM   #370
pmc
Hello Hanulec
I don't measured myself.
This information is acquired to the Top Racing Japan.
I think they have the thickness of the chassi in account, the standard chassi plate.
Best Regards:
Pedro Silva
Old 04-30-2012, 11:46 AM   #371
Bishop's Avatar
Ok, I reached the point of the bulk of car done, following the manual so up to doing the shocks...
Some things worth noting, screws not as horrible as my original kit, but still not great, new rear diff is a little strange, the oring means it's hard to 'feel' when the case is done up tight, you have to torque the case down what feels like very tight to stop the screw holes leaking, and the outdrive orings do seem to leak regardless what you do, maybe cause of the missing shims?
The real weird is when I reached building the shocks, I can't believe they still come with about .2-.3mm play from the piston on the shafts, it's seems so odd to not include some shims, old issue, no fix within a brand new kit/model?
Mixed general feel about the kit quality overall, it reminds me so much of the original kit, much of the quality is outstanding (including quality of material), but you hit a few problem areas that seem a strange let down among that.
Oh and the steering hubs have very little play, no shimming seems required there anymore (but new rack has a fair bit of play in it), I got a slightly wonky spur pulley that won't run true in my kit, and a camber link rod that is threaded the reverse to how it's marked!, but overall it's got some nice features and touched on the new kit.
Likely I'll order a few little bits to cleanly finish the build, or borrow some bits off the old car.
QRCCRA
www.qrccra.org.au
Old 04-30-2012, 01:46 PM   #372
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Originally Posted by E.J. Evans View Post
Video of my EX over the weekend at Norcal Hobbies.
**Sorry No Audio**
+ YouTube Video
Here is my Asphalt Setup.
Let me know of any questions.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 04-30-2012, 02:00 PM   #373
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
What are the optional shocks?!
What motor were you using?
Run the EX as per manual for the first time on Sunday. Although I thought it was too stiff surprisingly it was ok. Problem that I hadn't run this layout before and I had trouble finding proper lines...
I ended up with this setup
Very happy with the kit and it's durability as I did some airborne stands
Next outing will be in few weeks, on another track though, as we have this week national off road race!
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is offline   Reply With Quote
Old 04-30-2012, 02:27 PM   #374
E.J. Evans's Avatar
I'm using the Standard V2 shocks:
- 3 hole 1mm optional pistons
- Kyosho Grooved o-ring found here
I'll check out your setup ;-)
Old 04-30-2012, 02:29 PM   #375
E.J. Evans's Avatar
I'm using a 4.5.
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 08:03 PM
