T.O.P. PHOTON EX
#287
Just getting into my build...
The manual lists a 5x9x.1mm shim behind the gear diff outdrives but it wasn't in bag b...anyone else have this issue ?
Also, where should I start for diff fluid ? Large open asphalt track, good grip.
#288
Start at 2000 CST and once the o-rings swell up a touch (probably about 2 race days), you can go down to either 1000 CST or 1500 CST.
#289
I'll post my standard asphalt setup shortly.
#291
#292
Photon Build
For those building the car, I raised my roll center +0.5mm. I used our wide shims (same shims used to widen the hing pin) opposed to the standard M3 shim.
Also when putting together the steering knuckles use locktite. I add a small dab into the threads of the steering block. You only need a small amount. If you use too much it my leak out and bind up the steering.
#293
#298
