Old 04-23-2012, 04:02 PM   #211
Trader Rating: 19 (100%+)
Originally Posted by hanulec View Post
Kits are in at TOP USA. OD is crazy busy ...
DO WORK OD!
MDawson is offline   Reply With Quote
Old 04-23-2012, 04:40 PM   #212
bkspeedo's Avatar
Damn it, they didn't receive as many as they thought and i was not far enough up on the list. Have to wait for the next round
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 04-23-2012, 06:34 PM   #213
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Guy,s
Found a Edit Photon EX Sheet here. Hope this helps it was to large to put on RC/Tech.
http://www.rcring.gr/index.asp?page=...bf=Photon%20EX
Mike
At Jackson we only had practice. With that being said, id like a setup sheet too..
But I think an electronic editable one must be made first. Otherwise a photo if a printed / hand written one is good 4 me
I've gotten a bunch of spare parts built up for my EX
- shocks to 50.5mm length. 1.0 3 hole. 45 losi front. 40 losi rear. 324 front. 289 rear.
- high low suspension arm mounts
- LT wt arms
- front arms spaced to short wheelbase - 3.5mm of shim
- rear arms spaceing tbd
- spool built with Mira outdrives
- yokomo gear diff with 15wt losi
- 44.5 rear axles with filed down asc blades.
- xray 50mm ecs
- xray 4 degree chubs filed down to fit arms
Got a big list of items still to prep prior to kit arrival to make it race ready for Saturday
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 04-23-2012, 06:36 PM   #214
hanulec's Avatar
Trader Rating: 23 (100%+)
editable setup sheet - http://racerlog.com/wiki/T.O.P._Photon_EX#Setups
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-23-2012, 07:00 PM   #215
S.Stew's Avatar
So I'm having a look at your wiki there and I'm looking into the front axle suggestions. I am shocked at the prospect of needing $150 (figure w/shipping) worth aftermarket parts to make the car work right. Is this a really serious issue? I'll most likely only be racing on large asphalt tracks. My EX will be on its way tomorrow (!!!) and I'm super stoked to get back into touring car...just a little boggled by this.
S.Stew is offline   Reply With Quote
Old 04-23-2012, 07:08 PM   #216
hanulec's Avatar
nothing on my wiki is necessary. nor is it officially sanctioned by TOP. it is just what i and some others are/will be doing.
asphalt - unnecessary.
carpet - think about it.
unfortunately $50-$100 lcd/ecs/c.v. drive shafts are very common in all different manufacture cars.
Old 04-23-2012, 07:37 PM   #217
hanulec's Avatar
ready for carbon and aluminum...
Old 04-23-2012, 07:51 PM   #218
RCFREAK's Avatar
Trader Rating: 17 (100%+)
Originally Posted by MDawson View Post
DO WORK OD!
DO WORK HANULEC!
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 04-23-2012, 08:34 PM   #219
L.Fairtrace's Avatar
Send a message via AIM to L.Fairtrace
Ok here are a couple setup sheets.
Just something to start with.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 04-23-2012, 08:46 PM   #220
Build one more of those ARTR Hanulec kits!
Old 04-24-2012, 01:46 AM   #221
part-time racer's Avatar
Hi S.Stew. I've been a team driver with rcracinguk ( T.O.P. distributor ) for about 3 years now and have used the Photon since its release. In this time, I have raced the car on various surfaces ( tarmac high grip/low grip and carpet high grip and low grip). I've raced this car on tracks layed out using drainage down pipes and tracks designed from bot-dots. So I feel confident when I suggest to you that the car as supplied as standard is totally acceptable and durable.
The only hop-up I could suggest to you is the axel pin holders which will allow you to run the cvd's without the small grub screw which would normally lock down on to the cvd pin and potentially bind or fall out. This is a low cost option that really works well.
I hope this helps.
part-time racer is offline   Reply With Quote
Old 04-24-2012, 03:45 AM   #222
TeamWTF's Avatar
Does the car generate more front end then the original? Just looks like your trying to find rear end grip
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 04-24-2012, 04:32 AM   #223
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Received!!
Will post some pictures later on.
You can find online it's manual here and as already been pointed out editable setup here
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is offline   Reply With Quote
Old 04-24-2012, 04:49 AM   #224
*SBH*'s Avatar
Yes it feels like the car has a lot more midcorner steering than the old Photon.
*SBH* is offline   Reply With Quote
Old 04-24-2012, 07:56 AM   #225
Trader Rating: 54 (100%+)
Me too
Jamison R is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
T.O.P. Photon Mr Merc 916 R/C Items: For Sale/Trade 10 09-18-2010 08:03 PM
