muchmore power supply.. any help? >
Old 12-22-2004, 01:27 AM
Team-RTR's Avatar
Default muchmore power supply.. any help?
hi, i just recently purchased a muchmore power master 20A power supply from hong kong. i live in australia and in australia we use 240V power as opposed to 110V from hongkong. in the instructions it says that the power supply is either 110V or 240V, but it also says that it is pre adjusted from the factory and shouldnt be touched.. does this mean that if i plug it in it will blow up because there is too much current running through it?? thanks!!
Team-RTR is offline
Old 12-22-2004, 01:31 AM
Shop Owner
nnick's Avatar
Here are the instructions
http://www.rcingreece.com/index.asp?page=manuals
Choose MuchMore form the combo box and download the manuals
Nick
nnick is offline
Old 12-22-2004, 01:32 AM
Frank McKinney's Avatar
Go to the website or catalog where you bought the PS from and see if it's advertised as 110v or 240v. That should be your clue as to how it's configured.
The PS is considered switchable but like your computer PS it has to be switched over manually - in this case you have to disassemble the PS case to flip a switch inside. I haven't done this on mine since I bought and use my PS in the UK but if the website/catalog you got the PS from is no help you might want to try opening the case and seeing if there are any clues telling you what voltage the PS is ready for, or what switch to flip. I'd look for small numbers printed on the circuit board saying "110" and "240" or something similar if there isn't a clear clue telling you what the PS is currently set at.
edit: See my post below for a better link
Frank McKinney is offline
Old 12-22-2004, 01:33 AM
Pro4's Avatar
http://www.rcingreece.com/Manuals/Mu...110v_input.doc
Nick
Link doesn't seem to be working
Pro4 is offline
Old 12-22-2004, 01:34 AM
edit - the link doesn't work without removing the symbols for spaces and < and > signs (all the "%20" stuff), use this link
Old 12-22-2004, 01:40 AM
Shop Owner
nnick's Avatar
I changed the link to the main manuals page
Nick
nnick is offline
Old 12-22-2004, 01:54 AM
FYI you other guys, after you choose the Much More brand on the link Nick posted the cell master charger picture on the right is the picture you want. The link I posted is the same file renamed and put on my personal site.
Nick, the links we've posted show the instructions for changing the MM cell master charger from 110v to 220v, etc., does that actually work for the PS as well?
Old 12-22-2004, 02:20 AM
Shop Owner
nnick's Avatar
Hello Frank,
You are right there are 2 pictures of the cell master. The one is the manual and the other as the instructions for the change!
Stupid me, the instructions are for the PS there is no need to do anything on the charger!!!
I'll fix immediatelly!!
Sorry guys!
Nick
PS:
Hi Frank how things are going? We met in Japan on the 2002 HPI worlds!
nnick is offline
Old 12-22-2004, 02:23 AM
Ryan Lee's Avatar
Default Re: muchmore power supply.. any help?
Hello,
Open the case of Power master then you'll find 110V and 220V marks on the PCB.
Find squared shaped grey colored connector. Move it to another pin. If the connector places on 220V, it is adjusted for 220V.
If you bought Power master from HK, it must be adjusted 220~240V. but you need to open and check.
Thanks,
Ryan Lee is offline
Old 12-22-2004, 02:30 AM
Thanks Ryan, I thought the circuit board power links would be the same but wasn't sure.
Nick - hi! One of these days I'll visit Greece, I know it's popular with the Brits
Shop Owner
nnick's Avatar
Category fixed. I can't upload yet the picture since my host is down at the moment (ftp service)
Nick
nnick is offline
Old 12-22-2004, 02:32 AM
Shop Owner
nnick's Avatar
Give me a call when you do. I'll be happy to be of an assistance for you!
Nick
nnick is offline
Old 12-22-2004, 02:39 AM
Nick - YGPM
Old 12-22-2004, 03:21 AM
Default PSU
Thanks for posting the link to the pics we took for the UK site Nick.
Much appreciated.
Keith.
The instructions will also be posted on the Power Supply page on
the UK site.
click here
keithander is offline
Old 12-22-2004, 03:26 AM
Team-RTR's Avatar
hey guys.. i opened up the power supply and there is only one pin labelled 220V which it was already plugged into. it seems that the PS is auto sensing between 220V and 110V... is this true...?
Team-RTR is offline
